Thread: Leak with system running
    bear31088's Avatar
    Dec 2013
    Warner Robins, GA
    46
    About a month ago I posted a thread about my pool losing about an inch of water every day with the system running. Being new to pool ownership, I imagined the worst-case scenario - having to dig up my pool deck looking for plumbing problems. However, when I called my local pool supply store and explained my problem and what components made up my system, the lady there suggested a simple troubleshooting technique and I thought I'd share it with anyone else out there experiencing the same issue. For those with Hayward sand filters with the controls/valve on the top of the unit, make sure valve control is on the "filter" option. Turn the system on and monitor the "backwash" drain for running water. If there's water coming out of that, then the gasket in the function selector on top of the filter is bad. The fix is a ~ $8 dollar gasket.
    Barry, Central GA
    15X36 IG 14,200 gal fiberglass pool. Hayward Sand Filter with 1 HP Hayward SUPER PUMP. Pentaire "Kreepy Krawly Robotic Cleaner
    e-mail: oso49@cox.net
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Leak with system running
    I remember this. Glad you found out it was something simple.....what a relief!
    Essential Links:
    38,430
    I have lost almost 50% of my pool water before when the multi-valve did not fully seat in the filter position and water just dumped out of my drain line (which goes underground and to the back of the property). I now put a union on the waste pipe and leave it open so I can make sure I am not losing water through there.
    bear31088's Avatar
    Dec 2013
    Warner Robins, GA
    46
    Thank you.
    Barry, Central GA
