Results 1 to 7 of 7
Thread: Question about aeration and PH
    Jan 2014
    Ban ampur Thailand
    26
    Ok so I have been able to successfully lower my ALK/PH with acid and bring the PH back up with aeration ( mainly running the built in spa jets in the pool). My question is will running the spa continue to raise the PH? Basically what I mean once I get the ALK in the proper range will I risk going to high on the PH by using the spa frequently?
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Question about aeration and PH
    Any aeration from any source will contribute to increasing pH.
    You will still have to monitor pH often, preferable daily.
    You're done SLAMing when:
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Quote Originally Posted by Tuffy View Post
    Yes. However, the pH rise slows down as pH gets higher and TA gets lower. You've probably noticed that during your treatment. So if you find yourself constantly adding acid to lower pH, and the TA gets real low as a result, try letting pH hover at the upper end of safe.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    You will never risk the pH going too high with regular testing, and proper maintenance of it. The pH will never come to a point of "set and forget". It always has to be maintained over time.
    Yes, it will likely tend to rise in your situation, so just be diligent, keep an eye on it, and adjust it as needed.
    Essential Links:
    Jan 2014
    Ban ampur Thailand
    26
    My biggest worry is I am gone sometimes for 3 weeks at a time and the wife is left minding the pool. She isn't comfortable adding acid so I am worried the PH will get to high while I am gone. I was actually thinking about adding the"PH" system to my zodiac tri but have heard that it isn't reliable.....any thoughts?
    60000 L /15000gal L shaped infinity pool IG cement pool with 4" tile and grout
    28" sand filter / 1.5 hp hayward super pump 80 gpm
    Zodiac large size SWG, Taylor K-2006 test kit, 2 wheel suction side the pool cleaner
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Lower it before you go away, knock it down when you get back. Adjust your CH so that the CSI doesn't go too positive when the PH gets too high. Work with the pool.
    You can play with pool math to change some figures around. The other thing to look at is this link:
    http://www.troublefreepool.com/threa...jection+System
    Just like chlorine usage your pool has a daily acid usage.
    Jan 2014
    Ban ampur Thailand
    26
    Thanks bobodaclown iThat is a sound plan I'll give it a try next time and see how it goes
