Results 1 to 13 of 13
Thread: San Antonio Pool Quote Help
    Feb 2014
    San Antonio, TX
    9
    Need some help on a pool quote from our first PB. All comments and suggestions are welcome and encourage!
    The price is $76,798 for the pool portion and concrete around pool and walkway to the house. (Kitchen, Pergola and Firepit areas are not part of the price - just the pool, decking, and a few retaining walls).
    Pool
    19 x 36 Freeform
    101' permitier
    513 sq ft surface area
    3-6 depth
    Coping: Leuders
    Tile: 6x6
    Walls: Stacked stone
    Plaster: WetEdge Satin Matrix
    Raise pool wall with 2 18" water shears
    2 Hayward Color Logic LED lights
    Spa:
    7' round
    5 jets
    Raised 18"
    Hayward 2nd pump (need to get specifics)
    1 Hayward Color Logic LED light
    Equipment
    Hayward 425 sqft cartridge filter
    Hayward 2HP TriStar pump
    Hayward 400,000 BTU gas heater
    Automatic Inline chlorination
    Hayward Aqua Logic PS-8
    Aqua Pod remote
    Polaris 280 with booster pump
    820 Sq ft Salted and Stained Concrete
    All steps capped with leuders as well but not shown in image.
    Construction:
    • Dry Mix Gunite, Water and quality controlled at job site.
    • Steel Reinforced Concrete Structure- Designed in accordance with the American Concrete Institute ACI-318 Standard “Building Code for Reinforced Concrete”
    • Rebar tied on 10” Centers with a four Bar Beam and additional bars at all high stress areas. Pool and Spa are #4 Rebar, 60 grade.
    • 80% tie guaranteed with Galvanized Tie Wires
    • To comply with American Society for Testing and Materials (ASTM) No. A615
    • Minimum floor and wall thickness of 8"-10" (12" thick on Bond Beam and when out of ground)
    Plumbing:
    • All Pool Piping will consist of 2” Schedule 40 PVC
    • Two Pool and Spa Main Drains for Maximum Safety (2” suction back to Pump)
    • Pool Plumbing is VGB Compliant
    • Skimmer- (Qty.2) Surface Skimmer with Hydrodynamic Weir and 2” Suction Line- Independently Plumbed
    • Directional Returns: (Qty. 6) Proper Manifold for even Pressure
    • Overflow Line and Fill line
    • Independently Plumbed Pool Cleaner Line
    • Base Price includes 30` from Pool to Equipment Pad
    Electic:
    • Bonding by State Licensed and Bonded Electricians
    • Hook up of Underwater Lights, Timers, and Pool Pump
    • Includes Hook Up from Exterior Sub Panel and all required Circuit Breakers and GFI, etc.
    • Base Price includes 50` from Panel to Equipment Pad
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: San Antonio Pool Quote Help
    Welcome to TFP
    Looks like a nice backyard oasis!
    A few things you might want to give a closer look at...
    1. A 2 HP pump seems too large for your setup. My pool has similar dimensions (including the spa) but with a deep end of around 10' and I'm running a 1.5 HP (1.65 SFHP) pump which is plenty of pumping power for my pool. Plus, I run a Polaris 360 off of that pump without a booster. Question...is the pump in your spec a 2-speed or multi-speed? If not, I would definitely look into a 2-speed. A 2-speed of equivalent HP does not cost that much more than a single-speed, but it will save you lots of $ on your electric bill. Now's the time to look into this.
    2. Inquire into running a Polaris 360 or similar pressure side cleaner that does not require a separate booster pump.
    3. Curious as to the need for two main drains in the pool. One is all that's needed. In fact, many newer pools are being built without main drains. I would ask your builder to explain their reasoning on this.
    4. Filter: Are you sure you want a cartridge filter? Cleaning is much more labor intensive vs. sand or DE filters. My personal preference would be sand. It's as close to maintenance free as you can get. Many improvements have been made to the filtering efficiency of sand filters in recent years, so I would give them a closer look. Plus, proper chlorination plays the leading role in water clarity regardless of filter type.
    5. LED lights: Admittedly, it has been a couple of years since I priced these out. At that time, the LED pool lights were considerably more expensive than the traditional halogen pool light. While they will use less energy than the halogens, you may not get payback for some time unless you plan on having these lights on for several hours each and every night. If not, I would do a cost comparison vs. the halogens. Of course, if the color-changing capability is important to you, then my previous comments are moot. Love LEDs for in-house lighting (where the price points have come down in the last couple of years). Just have not seen LED price points come down enough for other applications.
    Vegas Kid's Avatar
    Dec 2013
    Cypress TX
    187
    Price seems pretty high to me, but I'm not sure about the San Antonio market.
    I would guess something like that would be closer to $60K at the most. To give you a comparison, one quote I got was for a geometric pool, about the same scope ie, hot tub, plaster, equipment, etc and it was under $60K.
    Dec 2013
    North Texas
    90
    I agree with Vegas Kid on the price. My build is similar to yours in many ways and our pool cost is ~$60k (not including the outdoor kitchen). Have you received other quotes? I narrowed it down to 2 PBs and had them create basically the same pool using the same equipment. Then I told them they were competing for my business and ultimately went with the PB that I felt most comfortable with. He did lower his cost to get my business and now we may be using them to put in an outdoor kitchen.
    I think there are many factors that drive that price but you may be able to get them to come down some.
    Our spa is in a similar place as yours and we lowered it. We have young kids and we want to eliminate hiding places. That then led to a raised wall with scuppers along the back to make up for the lost water feature with the spa.
    Either way, it is a great looking pool and I am sure you would be happy with it.
    Build is Done!: 18'x40' diving pool, depth 3'6" x 9', 104' perimeter, ~24k gallons, spa (6 jets), raised wall (3 scuppers), tanning ledge, Pentair IntelliFlo 3050 VS+SVRS, Pentair Clean & Clear 520 cartridge filter, Pentair MasterTemp 400 BTU heater, Polaris QT 1.5 HP blower, Pentair Intellichlor IC60 SWG, IntelliBrite 5G lights, Pentair EasyTouch 8 with Screenlogic2, 504 sq ft Roman Slate textured deck, Aqua Blue StoneScapes finish
    Feb 2014
    San Antonio, TX
    9
    Quote Originally Posted by mjworthy View Post
    First 76k did not include electrical panel upgrades or gas to the heater site. My gas and electric are on the opposite side of the house (off course). Its either a 180 ft. run around the house or 100 ft up and through the attic.
    We actually met with 6 builders. Got quotes from 5 of them. One was ridiculously high (way, way over 100K). One at 79K and another at 80K (no gas or electric) and the other was 90K (But that did include the electrical and gas runs from main panels, meters).
    So 3 of my quotes seem to be fairly close. The 90K one did include the gas and electric upgrades, but not the some plaster and coping upgrades. Taking some neighbors pools and adding on our upgrades...make it seem a little high.
    So I feel pretty good about the price comparatively speaking, but spending that kind of money always make one nervous.
    Readyforapool's Avatar
    Sep 2013
    DFW metroplex
    738
    Mine is also similar in size to yours - priced the same as Vegas Kid and mjworthy. My pool builder did tell me that prices go up significantly in January because business is good and people want their pools in before the weather warms up. I can tell you, prices in DFW seem to significantly higher than my Houston friends who were getting the same size pool for 40k. May just be the market in San Antonio.
    In my opinion, the lights are worth it!! We initially cut those trying to save some money but glad we changed our minds and added them back - love the LEDs! We did put off the spray deck for now since we wanted to do a patio cover and outdoor kitchen, decided we could do the coating later without to much issue. Good luck with your build.
    Finally Done! - 21x34 IG, SWCG, depth - 3.6 - 4.6 - 6.6, Pentair IntelliFlow 3050 vs+svrs, 60 sq ft Pentair DE Filter, 400k BTU Heater, Polaris 280 w/.75 hp booster pump, Pentair EasyTouch wireless, 38 sq ft raised spa, wet edge Barbados quartz finish - ODK w/36 in Napoleon grill
    Sep 2013
    DFW metroplex
    738
    Btw - mine did include the gas and electric runs that were on the opposite side of the house from the pool, I believe it was 120 ft - so i had both the back and front yards in construction mode for several months.
    Vegas Kid's Avatar
    Dec 2013
    Cypress TX
    187
    You should get a turnkey quote. Have them include everything...you don't want a bunch of extra things creeping up on you that you didn't account for.
    Regardless of the area, $76 is way too high IMO. San Antonio has plenty of cheap labor.
    Aug 2010
    Dallas, TX
    4,052
    You guys that are not familiar with San Antonio... the price may affect the fact that they most likely have to dig through solid rock to build the pool. We don't have that issue here in N Texas.
    Feb 2014
    San Antonio, TX
    9
    Quote Originally Posted by RobbieH View Post
    You got that right. After 3" you hit rock here in north San Antonio. 4 of the quotes are right around the same price or a tad higher.
    Vegas Kid's Avatar
    Dec 2013
    Cypress TX
    187
    If that's the case then maybe the OP can look into getting somebody else (3rd party) to do the excavation. If most of the cost is the excavation then maybe the OP can save some money.
    I would tell them you want to see the price breakdown per sub so you can see where the money is going. No guarantee they'll show you but I would ask. If nothing else I would call and get an excavation bid just to see if that is where all the money is going.
    We built our pool as an owner builder so I payed all the subs directly. Below is our breakout:
    Pool consultant $2500
    Plans $150
    Permit $208
    Electric and Plumbing $3700
    Excavation $1500
    Rebar $1950
    Gunfire $4900
    Tile $2702.90
    Concrete $5564
    Equipment $6490
    Pebblesheen $4507
    Fire pit $1529.46
    Dive Rock $368.75
    Our pool was pretty basic and it's in another region of the country but labor is labor and it shouldn't be 3 times the cost. If I had to pay that kind of price I think I'd be swimming in a irrigation canal.
    I love the design. Keep us updated.
    36 x 20, 3-1/2 to 8ft depth, 100 per. 20k gallon IG pool. Jandy Flopro 2hp vsp,
    Jandy 460 sq ft cartridge filter, Jandy Purelink SWC, Jandy Iaqualink control panel, Barracuda MX8
    Irish Mint Pebblesheen, Dive Rock, (2) 24" cascading water falls, LED pool light.
    36" Gas firepit with 1/4" Azuria and Cobalt Blue reflective glass. Our Pool
    Oops gunite
