Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: New Pool Quote Central TX - need advice
    Feb 2014
    Texas
    7
    I've really been enjoying reading everybody's posts on designs, suggestions and pics of construction. Have received two pool bids and am leaning towards this one. Just want to make sure there isn't something that I'm missing or any red flags. It's a lot of money to spend and don't want to sign a contract until I've vetted everything. Listing a lot of info, but would really like some advice if something seems out of whack. Also if anyone has any critiques of the design, that would be helpful too!
    Pool: 20' x 30' freeform gunite pool, 88 ft perimeter, 474 sq ft pool area, 3 x 4.25 x 5.5, 13,500 gallons
    Shell: 1/2" rebar on 10"centers, both ways; Bond beam 1/2" steel rebar x4; Thickness: 12" bond beam, 8-10" walls/floor (I'm a girl so I have no idea if this is good?)
    Pool pipes: up to 2 1/2" schedule 40 PVC
    Return: 4 directional inlets; Skimmers:2 Pentair; Drains:4 10"AquaStar; 1 cleaner line
    Reinforcement: 3/8"rebar 16" on center, 4" crushed base, 3/8" mastic joint
    Deck-o-Drain:6 ft (I don't know what this is?); drainage pipe 20 ft total
    6" band of tile at waterline, flagstone coping (prob OK)
    9 ft boulders notched in water (2.5 tone moss rock waterfall) I think 8 feet across
    1 bubbler on 55 sq ft tanning shelf, Pebble Sheen level 1
    Decking: 607 sq ft concrete deck with Sundek and existing 240 sq ft deck to add Sundek (prob Mission Tan)
    Pentair IntelliFlo VS-3050, Pentair WhisperFlo 1.5 HP pump, Pentair Clean & Clear 420 filter cartridge
    Kreepy Krauly cleaner, Easytouch P-4 control box; In-Line Chlor w Trident UV S2; Pentair AmeriLite 500w
    Cost:$52,500
    Cost to add Extra Options:
    Pebble Sheen Turtle Bay $1100
    Add Sundek Aggregate to 847 total sq ft:$1360
    Add 3 LED color lights: $915 (I think the Intellibrite 5g)
    Total with options: $55,875
    Dec 2013
    North Texas
    90
    Re: New Pool Quote Central TX - need advice
    Hi Minniemousemom! I think your build looks pretty good, however, it does look a little high. Where area in TX do you live in?
    We struggled with capping our existing patio which is similar in size to yours and we ended up doing it. It is much better to do it now than try to do it later and we were scared that we would be mad at ourselves for not doing it in 2 years. We also went with the Intellibrite 5G lights because we have young kids and will use the light show. That is purely a preference call and not for everyone.
    Let us know when you sign the contract. It is going to be a great looking pool!
    Build is Done!: 18'x40' diving pool, depth 3'6" x 9', 104' perimeter, ~24k gallons, spa (6 jets), raised wall (3 scuppers), tanning ledge, Pentair IntelliFlo 3050 VS+SVRS, Pentair Clean & Clear 520 cartridge filter, Pentair MasterTemp 400 BTU heater, Polaris QT 1.5 HP blower, Pentair Intellichlor IC60 SWG, IntelliBrite 5G lights, Pentair EasyTouch 8 with Screenlogic2, 504 sq ft Roman Slate textured deck, Aqua Blue StoneScapes finish
    38,548
    Welcome to TFP!!!
    A couple things jump out at me:
    1. Your choice of copping and waterfall rock have eliminated the possibility of ever switching to a saltwater chlorine system ... so you will have to use liquid chlorine / bleach. There is a spec for an in-line chlorinator which is all but worthless as it uses trichlor tablets which are not a viable long-term solution. Read this: How to Chlorinate Your Pool
    2. Put on your bathing suit and go lay out in your yard for as long as your pool will be exposed to the sun ... everyday. Then come back and tell me that your pool will not be getting enough UV from the Texas sun ... UV and ozone systems on private outdoor residential pools is just a waste of money, both in upfront cost and added need for electricity.
    Verify that the floor and skimmers will be plumbed separately to the pump with valves to allow you to adjust where the suction comes from ... and realize that true pool valves are MUCH better than using PVC ball valves.
    I would also suggest you read all of Pool School a few times if you have not already. A little bit of time in there and you will quickly know more about pool chemistry than your builder and most pool store employees.
    Feb 2014
    Texas
    7
    The bid does show the skimmers will be independently plumbed for optimum control.
    All pool builders have suggested we not go with salt water. It seems everyone is on a different side of the fence on this one.
    Yes, I have read on here that the UV/Ozone equipment is a waste, but haven't brought it up with the builder yet. Still getting my ducks in a row. Should it be eliminated and replaced with something else or I can just get rid of it and use chlorine?
    Can anyone tell me what I should be paying for a concrete deck with Sundek per sq ft? Just a general idea? Based on the two quotes, it seems one is around $10 and the other $15. Not sure why it would be that high? That's excluding adding the Sundek aggregate.
    Any opinions on using flagstone for the waterline as well vs using tiles? (assuming we don't want salt water)
    38,548
    You have to use chlorine even if you did have the UV/Ozone so I would eliminate it completely. Maybe consider getting a peristaltic pump to automate the bleach addition with the money you save?
    They likely do not recommend the SWG because all the builders down there seem to only want to use the natural stone. I would not think that flagstone at the waterline would be a good idea.
    To me $10 per sqft of 4" concrete slab seems a bit high, but I have not shopped for prices in a long time.
    It does seem quite high. A lot of similar features as our pool which we paid just over 36k for.
    I am sure there's different variables for different parts of the country. For instance the dig took us about 6 hours total and we paid $1400.
    36 x 20, 3-1/2 to 8ft depth, 100 per. 20k gallon IG pool. Jandy Flopro 2hp vsp,
    Jandy 460 sq ft cartridge filter, Jandy Purelink SWC, Jandy Iaqualink control panel, Barracuda MX8
    Irish Mint Pebblesheen, Dive Rock, (2) 24" cascading water falls, LED pool light.
    36" Gas firepit with 1/4" Azuria and Cobalt Blue reflective glass. Our Pool
    Vegas Kid's Avatar
    Dec 2013
    Cypress TX
    187
    Price seems a bit high but it may be the boulders and other stone. Those add up quickly.
    For 88 lnft I'd have to think you'd be under $50K including those options, unless you're going with a high end builder. Oh wait, just saw no hot tub....that price is definitely high. Would think closer to $40K
    Don't forget to ask making sure they include running a gas line for the heater, sprinkler repair, grass replacement, any additional electrical work, etc.
    Have you gotten other bids yet?
    rodog123's Avatar
    Nov 2013
    Pearland, TX
    308
    We are paying $9 per sq. foot for concrete, rebar and coated with sundeck. We are in Houston Texas.
    Completed 38'X21' IG Free form pool approx 18.5K gallons, sports pool w/spa and tanning shelf 3.5-5.5 ft. Jandy Cartridge Filter, Jandy stealth pumps, Jandy LXi Heater, I aqualink, Inline chlorinator. Click to see My Pool Build
    Feb 2014
    Texas
    7
    I think the moss rock waterfall adds around $3k. Just want to make sure this pool isn't priced too high compared to other people building a new pool in central Texas.
    Depending on what part of Central Texas I have heard of pool costs being much higher because of the dig. In the Austin area I have been told it's much more difficult because of the limestone.
    11K SWG Freeform IG pool w/ spa; Bluehaven 550 (hayward mfg) Cartridge Filter; Century Centurion 2HP Pump on pool; Hayward 400H heater; Polaris PB4-60 Pump on cleaner; Hayward Super II Pump on waterfall, Hayward TurboCell GLX-Cell-5; AquaLogic PS8, Taylor 2006k
    Pool Chlorinator @ 80%; Filter from 11AM-6PM, Cleaner from 11AM-2PM
    May 2013
    Round Rock, TX
    138
    I would say you're a little high without a hot tub. If you want to PM me, I can point you to our builder who did a wonderful job!
    35'x16' IG geometric with 8'x6' spa (16.5K gallons); White Diamond Pebblesheen w/Abalone Shells; Jandy 460 cartridge filter; Jandy 2HP E pump; Jandy 400K heater; Water Tech Blue Diamond Pro; TF-100 w/SpeedStir
    Feb 2014
    Texas
    7
    If anybody can recommend Austin pool builders, please let me know.
    Feb 2014
    Texas
    7
    We also got another quote from a PB and he placed the pool 6-8 feet from the patio parallel to the house, which would also make it centered to our living room windows. Any opinions on pool placement? Who likes the pool a few steps from the patio vs a pool that is a lot further out in the yard and moved over from the patio? The design above has it moved over to the right, more in front of the breakfast area window.
    Dec 2013
    North Texas
    90
    Our spa and water feature are centered and close to our current patio. We did that so that some of the nice features of our pool catch your eye from our living room. I think yours would look nice either way and it really comes down to personal preference.
    May 2013
    Central Texas
    42
    Built last year with an independent builder (yours looks more "national"), prices seem high for what is being offered. Since the independent needs to do warranty work and is slow responding, screw him and I will not recommend (for now). PM me for details.
    +/-16k gallon IG pebblesheen pool with SWG, spa and waterfall, Hayward 2HP 2-speed Tri-star, Hayward 1.5HP Tri-star, Hayward 5030 Cartridge filter, Hayward H400 Heater, Sharkvac Robotic Cleaner
    Feb 2014
    Texas
    7
    PB came back and said we could eliminate the second pump for the waterfall and just use the Pentair VS pump. Is that ok to do that or do we really need a separate pump? Any recommendations for the cleaner? We currently have the Kreepy Krauly Platinum in the bid. Is that a good model?
    Shouldn't be a problem we have only one 2hp pump.
    We have the mdx8 and it has rescued us from countless dust storms in the drought stricken California.
    38,548
    "The Pool Cleaner" gets great reviews for a suction cleaner ... The name could certainly be better
    Vegas Kid's Avatar
    Dec 2013
    Cypress TX
    187
    Quote Originally Posted by Minniemousemom View Post
    We chose to offset our pool since we wanted to keep alot of yard for the kids. I find that although it looks good, having the pool smack dab in the middle of your yard takes up a lot of space.
  20. Back To Top    #20
    May 2013
    Round Rock, TX
    138
    Is go robotic cleaner but that's just me.
