Results 1 to 10 of 10
Thread: Spa draining overnight
    Feb 2014
    Coppell, TX
    14
    I have an attached spa with a waterfall feature into the pool. Overnight, the spa drains down about 9-12" (just above spa jets). I have opened the check valve made sure it was working and no foreign objects. I checked both suction and return valves as well, no foreign objects, seals seem to be in good shape. All the people I have asked, say it is most likely the check valve. However, I happen to have a ball valve that I can close and I did that, but it still drained. I am stumped. Any ideas from any of you experts? I assume the water is just draining back into the pool, but could it be a leak?
    Oct 2007
    Parkland, FL
    752
    Re: Spa draining overnight
    Has it always done this? It's common to drain back to ground level when the pump isn't on,mine does this every night.
    8000 gal diamond brite pool with 650 gal spillover spa, Pentair 3hp VS pump. Jandy Cartridge filter and Jandy Heat Pump. Jandy PDA automation system with 2 Pentair Laminars. SmartPool NC74S Robotic Pool Cleaner.
    38,284
    That should not happen if the correct check valves are installed and they are not leaking.
    Does it drain down to pool water level or lower?
    Feb 2014
    Coppell, TX
    14
    So overnight, about 16 hours it is draining down to about a foot above pool level. It has not always done this. We have been in the house for a little over a year and it used to only drain down a few inches.
    Approx. 14k, IG, plaster, cartridge, 2hp, attached spa
    38,284
    Well, since the spa water has not gotten below the pool level, it is hard to say if it is a leak or if the spa water is making it past the valves back to the pool.
    Can you add some pictures of your plumbing setup?
    Feb 2014
    Coppell, TX
    14
    38,284
    Need more angles, can't identify where some of the pipes go. What is that red valve, a heater bypass? What is that line on the ground where the spa return goes underground?
    Feb 2014
    Coppell, TX
    14
    Here is more pic. If I try to upload more it tells me I have exceeded my quota. Any idea how to fix that or another way to post pics. Sorry, I am new to the forum and still trying to figure it out.
    The red valve controls the waterfall out of the spa into the pool. After they check valve that line circles back to the spa return.
    38,284
    Host photos on Flickr or Photobucket, etc and post links here. Saves forum bandwidth.
    There is a check valve on the line with the red valve? That is what I would suspect.
    Feb 2014
    Coppell, TX
    14
    Yes, there is a check valve on that line, I replaced the seat assembly, checked for obstructions, mad checked the spring. All looks good, should I just replace it with a whole new one? Any thoughts on which one to get?
