Results 1 to 7 of 7
Thread: OMG I think I screwed up already
    Okay, so I after I got my water tested I added CYA to my pool. I thought I read somewhere to add it to the skimmer so this is what I did....the filter was on....I hope that was right I started getting nervous about that so I also added some directly to the pool. It is now sitting on the bottom of the pool. So now what?
    First did I mess up by adding it to the skimmer?....FYI I just learned what the heck a skimmer was for today
    Will the CYA sitting on the bottom of the pool mess up the liner?
    *1st time pool owner
    Just installed this week
    15x30 AG Pool
    15,400 gal. IG Gunnite
    1.5 hp Champion Pool Pump
    3/4 hp Century Pool & Spa Motor
    Pentair Automatic Chlorine Feeder
    Crystal Water Pool & Spa Cartridge Filter
    Polaris 280
    NCFlyersFan's Avatar
    May 2008
    NE North Carolina
    116
    Re: OMG I think I screwed up already
    Welcome to TFP!
    There is no real problem with adding the CYA to the skimmer. Just don't backwash or clean the filter for about a week to make sure the CYA is fully dissolved. As for the stuff on the liner, just brush it a couple of times a day and it will eventually dissolve.
    I like to put my CYA in a sock in the skimmer. It dissolves just fine and doesn't make a mess.
    13,000 gal AGP, Hayward X-Stream 100 sq ft cartridge, 1 HP Hayward Power-Flo Matrix Pump, all on two 6-hour on cycles per day. Baquacil to BBB convert.
    "It is necessary for us to learn from others' mistakes. You will not live long enough to make them all yourself." - Hyman G. Rickover
    Guest
    Pouring the CYA into the skimmer and then not cleaning your filter for a week is the easiest way to add it to your pool and is the way that is most often recommened by the manufacuters and most pool professionals, myself included.
    Mar 2007
    Coastalish 'down easter'
    4,160
    I've also added cya through the skimmer a number of times but... we had a pool ~6 years ago where the owner had added ~ 6 lbs in the skimmer all at once (just dumped the bucket in) and it clogged the skimmer line so badly that we ended up having to abandon the line and open up the reserve line to keep the skimmer functional Ever since then, I've used nylon kneehighs to add the cya via the skimmer!
    I'm not saying that adding it directly through the skimmer will cause a problem, but go slow and make sure it's passing through the line!! 8)
    Luv& Luk
    -Ted
    Guest
    Quote Originally Posted by waste
    Well, that's just common sense, isn't it?
    Mar 2007
    4,160
    Evan, sometimes 'common sense' isn't all that common
    btw Check your mailbox on Tues or Wed
    Luv& Luk
    -Ted
    May 2008
    Minnesota
    53
    CYA does suck at getting dissolved so what i did was take an extra net that goes to my leaf vac and i pour the stabilizer in it and then set that in the skimmer in the basket. it works much better than putting it in the pool and having it not go away.
    20k fiberglass w/ vinal liner, 1Hp magneTek Centurion Switchless Motor, Hayward Pro Series high rate 20" sand filter, Hayward RP 2100 Digital Heater.
