Results 1 to 13 of 13
Thread: Cover Collapsed :(
    Cover Collapsed :(
    Just looked outside in my backyard and this happened.. Yeah cover tore and ripped the aluminum guide rails right out of the concrete.
    My thought is it must have a leak or multiple leaks in the liner an/or the bottom drain line is broken underground. It was full when we closed it. I may try and submit this through my insurance. Id assume pool is partially covered under my policy. I will likely need:
    Liner
    Cover (solar and maybe mesh?)
    Concrete Repair since rails are ripped out
    Not sure why the previous owners replaced the mesh suspension with this other vinyl cover that glides on rails. Mesh would have likely still supported weight of snow even with water loss.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Cover Collapsed :(
    Wow that stinks
    As much snow as we have gotten, I doubt any cover would hold it. Generally, when it comes to covering where there is snow, the cover sits on the surface of the water so that it does not take up any snow load. It does look like you had a leak...with that said, I assume you drained the pool somewhat when you winterized but did the cover have any slack in it so that it would not have to hold the weight of the snow?
    Quote Originally Posted by linen View Post
    Wow that stinks
    Yeah.. the pool was mostly full when PB closed it.. so def a massive leak.. what's weird is there was no leak all summer long or even when we closed.
    Vegas Kid's Avatar
    Dec 2013
    Cypress TX
    187
    Man that really stinks.
    Wonder if some sort or low voltage radiant heating system could have been placed on top of the cover and turned on during large snow storms.
    Thinking something like a floor heating system or one they use on driveways.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Do you have an autofill?
    Nope
    Quotes came in and new liner and cover is going to run about $5k which is what I expected.. I am also going to be swapping out the cartridge filter for a Hayward S210T.
    JoshU's Avatar
    New Orleans, LA
    542
    Sorry to see that happen.
    That is more snow on the ground then I could ever imagine.
    Josh Ulfers - josh@saltpoolguys.com - 888-725-8766
    SaltPoolGuys.com - AutoPilot Pool Pilot Systems, Parts & Cells - AquaCal Heat Pumps
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    Quote Originally Posted by JoshU View Post
    Really? lol. My hot tub is supposed to be delivered in 3 weeks. Its going in my sunroom, I think you can see it here. (pool is on the left)
    40 x 16 IG Vinyl. Goldline SWG
    160 Sq Ft Roof mounted solar array
    2014 Hydropool Serenity 5000 Hot Tub
    The Pool School- A great place to start
    Jason's Pool calculator
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    Quote Originally Posted by Molson View Post
    Does not compute for a Texas boy.
    IG gunite/plaster pool/spa Started 1/17/14, Plastered 5/16/14
    Size: 12'-21'x39' free form, depth ranging from 4' to 7, attached 6 person spa with spillover.
    Equipment: Whisperflo 2hp pump, Pentair 30" sand filter, Pentair Mastertemp 400k BTU heater, 1hp Whisperflo for waterfalls, and a blower for spa floor
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    Quote Originally Posted by mrcarcrazy View Post
    Just think of it this way, I pile all my pool water in one spot for winter storage.
    bridgman's Avatar
    Mar 2014
    Bowmanville, ON Canada
    461
    So I'm guessing you've probably never lost a vehicle in the snow and had to poke around with a stick to find it ?
    Cedar hot tub, 680 US gallons - Snorkel wood-burning heater, canoe paddle, "offline" Intex 1000 GPH pump/filter with skimmer
    JoshU's Avatar
    New Orleans, LA
    542
    Here's my truck in the New Orleans version of snow:
