Results 1 to 9 of 9
Thread: Pump Won't Come On
    heren916's Avatar
    Feb 2014
    Sacramento
    4
    Pump Won't Come On
    Hi, when I went out to turn the pump on (I don't have mine on a timer) I flipped the switch and nothing. I replaced the switch and still nothing. It is a centrifugal pump with trap, PEA series Model and I'm not sure what other info I need to post. Please tell me it is not the motor which I replaced probably in 2003. Thank you.
    38,235
    Re: Pump Won't Come On
    Welcome to TFP!
    Is there a start capacitor on that motor? Although honestly getting 10 years out of a motor is pretty good these days I think.
    heren916's Avatar
    Feb 2014
    Sacramento
    4
    Hi, and thank you for the welcome and trying to help me. It is much appreciated! I'm looking at my owner's manual for the pump and in the diagram it shows a Capacitor. Re: getting 10 yrs use - all of my equipment is the original from 89. I've had to replace the cloth filters and the motor 3 times and each time I turn it on I say a little prayer - either he wasn't listening or I forgot this last time.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Was the motor making noise prior to this episode? I second the start capacitor.
    Check this info out:
    http://www.troublefreepool.com/threa...l=1#post603542
    Sounds like the start capacitor.
    Easy fix.
    http://www.youtube.com/watch?v=KKNvYeAAmjg
    or
    http://www.youtube.com/watch?v=vbIOltG4OaE
    Pumps may be a bit different, but it's the basic idea.
    Look on the old one and match it to the new one. Less than $15 delivered.
    http://www.ebay.com/itm/Pool-Motor-S...-/200841201921
    No affiliation with any of the above links.
    22,537
    Does it hum when you try to start it? If so, I agree with the capacitor.
    heren916's Avatar
    Feb 2014
    Sacramento
    4
    Hi and thanks for your help - sorry for delay in responding - re: noise - no the last time I turned it on - it was fine. I will check out the links you supplied - thanks again.
    Hi and thank you. No the last time I turned it on - it was fine - that is what puzzles me.
    22,537
    It could have been a sticking centrifugal switch. It may or may not happen again for a long time.
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    Nobody has mentioned it, but is the circuit breaker off/tripped?
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    heren916's Avatar
    Feb 2014
    Sacramento
    4
    Hi and thanks for the suggestion - it is the first thing I checked. My neighbor came over to check what was and wasn't getting power - unfortunately, I need a new motor and he said with the new motor I will want to replace the seals and something else (sigh)...I appreciate your help - thank you.
