Thread: Hayward Pump Trips Breaker
    Feb 2014
    Az
    2
    First time post as I just found this site. I wish I had known of it sooner.
    I have a 1/2hp Hayward pump for a 10,000 gallon in ground pool. The pump trips the breaker every time I turn it on. It will humm for 5-10 seconds, then trip the dual post breaker (2 x 15). I read here that it is good to test the capacitor before doing any major work. I did today, it was bad, and I replaced it. Thinking that I had it solved, I reset breaker and turned on pump. Same thing, hum for 5-10 seconds then trip the breaker. I also smell some burning type smell.
    I had previously removed the pump from the filter basket. The impeller was free spinning. I did find a couple of tiny stones near the impeller casing, and removed them.
    I am now at a loss. Any ideas on what could be wrong? I am hoping not to hear that I need a new pump. It is almost 8 years old, but would think that they last longer than that.
    22,542
    Re: Hayward Pump Trips Breaker
    It could be the start contacts. Did you check to make sure they were making contact?
    Feb 2014
    Az
    2
    Are these the contacts on othe capacitor?
    22,542
    No they're in the end of the motor over the shaft. They usually look like a vee.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Here's some info I posted in another post.
    Sounds like the start capacitor.
    Easy fix.
    http://www.youtube.com/watch?v=KKNvYeAAmjg
    or
    http://www.youtube.com/watch?v=vbIOltG4OaE
    Pumps may be a bit different, but it's the basic idea.
    Look on the old one and match it to the new one. Less than $15 delivered.
    http://www.ebay.com/itm/Pool-Motor-S...-/200841201921
    No affiliation with any of the above links.
