Thread: Water in standpipe
    Jul 2012
    New Mexico
    66
    Water in standpipe
    I was doing the monthly rounds yesterday, checking on the winter status of all the pool equipment. Took off the skimmer lid to see if anything exciting was going on in there.
    There was water in the standpipe. I am in NM so we do get freezing weather and all the equipment does get winterized. I went and opened the basket lid on the pump and that is dry.
    This is the second winter that we have had the pool after installation. First winter the PB did the winterizing with me in attendance taking notes and helping. This winter I did it myself. I am DIY type of guy and do my own maintenance.
    I did put some RV antifreeze down the standpipe in the winterization process. The water in the standpipe yesterday looks clear.
    Should I pour some more antifreeze down it from the pump end? Anything to worry about? I'd rather not be bustin' pipes under the decking two years in.
    Thank you in advance for any guidance.
    J.
    In New Mexico 20'x36'/3.5' to 8.5'/32,000 gallon/IG gunite/plaster
    Pentair WFE-4 pump/Pentair CC420 cartridge filter/Raypak 266A heater
    2 Pentair Intellibrite LED's/6 Aqua arches
    Coverpools cover with hidden lid
    1,500 sq ft stamped concrete deck
    Polaris robot
    TF100
    22,553
    Re: Water in standpipe
    If you poured antifreeze in it, it should be fine. You can add a little more for peace of mind if you want.
    Jul 2012
    New Mexico
    66
    Sounds good, last winter I don't remember any liquid visible in the pipe.
    J.
    Polaris robot
    TF100
