Thread: Snow Weight on Winter Cover
    Jul 2013
    Grand Rapids, Michigan
    55
    So we've had about 85 inches of snow so far in Michigan and approximately 36" of it is piled on my winter cover(inground). Should I be worried about the weight? Not sure if I should go out and try and pull some of the snow off or not. Any feedback would be appreciated.
    23,200 gallon in ground pool, Vinyl Liner, Salt Water, Variable Speed Pump Intelliflow 3hp/1.32SF/3.96 SFHP, Filter Pentair FNS PLus DE FNSP36, Heater Pentair Mastertemp 250, SWG Jandy APURE35PLG, TF-100 Test Kit
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,075
    Re: Snow Weight on Winter Cover
    There's really not a thing you can really do at this point. Once it starts to warm up (IF it ever does) then you'll want to drain some of the water off, but for now I wouldn't worry. In all honesty it's probably a solid block of ice and there's nothing you can do to move any of it anyways.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    The water is holding the weight of the snow, not the cover.
    ps0303's Avatar
    Jul 2011
    FL
    3,682
    I say put on the ole swim suit and head out with a broom and get some of that snow off of there. LOL
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Jun 2012
    western NY
    1,559
    Quote Originally Posted by JohnT View Post
    The BLOCK OF ICE is holding the weight of the snow, not the cover.
    Fixed it for you
    SW Indiana
    9,198
    Quote Originally Posted by danpik View Post
    Fixed it for you
