Results 1 to 9 of 9
Thread: Do robotic cleaners save energy compated to suction cleaners?
    Hi,
    Suctions cleaners like the Baracuda G2/G3 etc don't need electricity - and robotic cleaners do. However, I have read that robotic cleaners can save up to $300 a year - is this true? If so - how?
    I am tossing between Barccuda G2 and Zodiac V3 (Polaris 9300) for my Viron p320 variable speed pump setup.
    G2 is a lot cheaper to purchase initially...
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Do robotic cleaners save energy compated to suction cleaners?
    Vac cleaners are not always a good option.
    What size is you pool?
    Essential Links:
    22,551
    The issue with suction cleaners is that you have to run the main pump fast enough so that they work properly and that usually requires a lot more power than a robot cleaner does. So running a robot saves a lot over running the main pump to clean the pool.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Quote Originally Posted by Milan View Post
    Hi,
    Suction cleaners do use electricity because the pump needs to be running to use them. With your variable speed pump, you'll have to run at a higher speed to use the cleaner.
    30,427
    Generally (There is an article in Pool School), the cheaper the cleaner, the less cleaning power you get. The size of your pool should influence how much you pay.
    Jun 2013
    SpringHill FL
    415
    With a robot you cant be in the pool while it is. Suction or presure cleaners you can. Just throwing that out there as part of your decision making process
    Nathan
    15x30 gunite 18k gallons Hayward star clear plus 120sqft cart
    Yes they do...
    Easytouch, Intelliflo, Intellichem, Acid tank with pump, Intellichlor and Autelis network interface.
    Dec 2013
    Newcastle, NSW, Australia
    31
    I've found the robotic cleaners do a far better job, and faster, and use less power - I've a Zodiac V3, its brilliant.
    Brand new 30,000 Litre (~8000Gal) inground Leisure Pools fibreglass, Astral Pool Viron 3 speed 1.5Hp P320 pump, Hurlcon VX 3 T SWCG, Hurlcon ZX100 cartridge filter.
    Two mustard algae events, lots of bad pool store advice - double the salt level it should be (sigh), large amounts of copper based algaecide, 50 litres of 12.5% liquid chlorine, 2 litres of clarifier. $300 in chemicals in two weeks.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I'm going with one primarily to avoid having another pump for a pressure side cleaner in place.
    Less to break, less energy, and less noise.
    I took advice from the experienced to make the decision which also said, you get what you pay for. "More $$$=more cleaning power." So, I spent about the same as what a booster and cleaner would have cost me on a Robot. I'm looking forward to trying it out as everything else.
    Essential Links:
