Thread: Blue Pearl vs Blue Diamond
    Hi - I have an 18x36 IG gunite with a broken polaris (the high pressure line broke under the concrete)
    Instead of fixing this (it will probably cost almost as much as a robotic) I'm thinking of getting a blue pearl. Is the blue diamond worth the extra money. Pool shape is irregular with lots of curves.
    I had almost the exact same situation last year. My pool is 20 x 40 IG Vinyl an my polaris line broke. After getting cost estimates I plugged the line and bought a blue pearl and have never looked back. It works great. The filter bag does a great job polishing the water and gets stuff out that my huge DE filter does not. No need to buy the expensive one in my mind.
    20x40 IG vinyl, heatpump and solar and 3 siberian huskies, 10kw PV solar electric system. Nikon Photographer D800e dSLR.
    I have a Blue Diamond RC. I really like it, but after I got it, I realized that I probably would have been just as happy with a Blue Pearl. I have a particular situation about my pool with toe stubbers in the bottom for returns that I was worried the cleaner would get hung up on, so thought I needed the remote. I've had such problems with this with any of the suction side cleaners I had tried before. The BD goes right over them with no problem, and I'm sure the Blue Pearl would, too.
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
    Well I opted for the Blue Diamond mainly for the 4 year warranty. Was only $300 more and comes with a caddy and hopefully will last longer.
    Will update when it arrives
    Toronto Canada
    I just received my Aquabot Viva, which is essentially the same as the Blue Diamond remote control model.
    I'll review it after I use it a couple of far looks promising.
    I actually paid less for the remote model than the list price of the Blue Diamond without remote.
    Above Ground / 18' Round / Vinyl Liner / Sand Filter / 100K Gas Heater / Salt Added / No Nature2
