Results 1 to 8 of 8
Thread: Didn't winterize this year, a few issues, have questions
    Glock's Avatar
    Jun 2012
    Mesquite, Texas
    866
    I chose to leave my pool operational this winter and for the most part its been a great idea. I had one day when the temps got down to about 18 and we had a 18 hour power outage. The lines started getting slushy and with no ETA on power restoral I had no choice but to disconnect the lines and let the pool drain below the return to avoid equipment loss. The next day power came back and I put it all together, refilled and bumped the chlorine to normal.
    A few weeks ago I had dropped the garden hose in the pool to top it off. When it was done I left it in the pool but turned off the faucet. About a week later we were expecting sub-freezing temps again so I disconnected the hose from the faucet and put on the faucet cover. The next day I noticed the pool was down about 12" from the day before. After some Sherlock Holmes investigating I found the hose had achieved a syphon and had slowly drained overnight. I refilled, checked and added chlorine and we are once again good to go.
    Now, I said all that to explain why I now have 0 CYA. All my other numbers look good except my PH which is a little low (7.4) but that is to be expected. My question is, would it hurt to use a floater and some Trichlor tabs to slowly increase the CYA over time since it is still winter here while also adding chlorine or should I just buy the CYA. I had a 25lb bucket of CYA but I am out now and was about to order but I am looking for alternatives to having socks full of cya in my pool for more than a few days. I was thinking of using the floater and checking the CYA once a week until it was 30-50ppm then switching back to liquid bleach. Any feedback is appreciated.
    18x34 Doughboy AGP 22300K Gallons - Build Thread
    Aquaview 24" Sand Filter - 1.5 HP Powerline Pump - Barracuda Ranger - Taylor K-2006 - BBB
    Pool School and Pool Calculator
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,080
    Re: Didn't winterize this year, a few issues, have questions
    Tabs aren't a bad thing, when used correctly. Your plan on using the "leftover" tabs is dead on the money. Just keep track of your results and you'll be just fine.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    +1 to what Leebo stated.
    If you regularly test the CYA as planned, you will be fine. The chlorine demand is low right now as the pool water is likely at, or close to, its lowest temperature of the year combined with the limited sunlight of winter. That gives you the luxury of building up your CYA slowly using the tabs. Just be aware that as we get into the second half of March in the DFW area, that equation begins to change rather quickly as the days get sufficiently longer and the sunlight becomes more intense. Both of these factors will increase the chlorine demand. By then, if your CYA is not within a few ppm of 30, you might consider adding a supplemental dose of 100% CYA by adding it to an old (but clean) gym sock and placing it in the skimmer or hanging it in front of a return line. But for now, the tabs are the easiest way to bring the CYA up while keeping your pool chlorinated.
    One other thing...Keep an eye on your pH while using the trichlor tabs. Tabs are acidic and will lower the pH. If your pH falls below the recommended range, use washing soda or soda ash to increase it.
    Glock's Avatar
    Jun 2012
    Mesquite, Texas
    866
    I had not thought about the pH changing. I guess I will buy the CYA since I would have needed to buy the floater and tabs anyway. Ok, so CYA it is. lol
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    +1 to Bo on the use of tabs and the effect they have on pH.
    Good reminder Bo.
    Essential Links:
    Glock's Avatar
    Jun 2012
    Mesquite, Texas
    866
    Well, in all honesty I would have thought about it. After the fact when the pH crashed and I came on here to ask why. lol
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Hey, better now than then!
    Essential Links:
    aussieta's Avatar
    Jan 2014
    Langwarrin, Victoria, Australia
    488
    you are measuring CYA at room temperature aren't you
    otherwise you will get incorrect readings
    SWG inground peanut shaped eco-bright concrete pool
    50,000 litres 13,000 gallons
    Lincoln Salt Chlorinator, 25 gram cell Sand Filter with glass media
    Taylor K2006-C test kit, Taylor K-1766 salt test, Dolphin M500 pool cleaner
    are you taking care of your pool or is the poolshop taking care of you
