Thread: fuse stuck
    Feb 2014
    Katy
    1
    fuse stuck
    My pentair chlorine generator deos not have power on. I am trying to get the fuse out.
    Thanks to the instruction from some postings, I was able to get the fuse fixture cap out. However, only thing I pulled out was the fixture cap without the fuse, the fuse was stuck on the power unit. Any advice on how to get the fuse out?
    Thanks a lot!
    22,553
    Re: fuse stuck
    Turn the breaker off and make sure the power is off. Take an electrician screwdriver (1/4" straight blade) and stick it into the fuse and see if it'll twist it out.
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    Re: fuse stuck
    I have seen several of those fuse holders melted from high current/bad connection. You may need to replace the whole fuse holder(521248Z), if you cant get the fuse out. It should just fall out of there.
    Factory Warranty Station for:
