Thread: What is the best Natural Gas Heater for a 750 SF pool?
    Feb 2014
    Jersey side of Philadelphia
    93
    Thanks for your thoughts
    38,305
    Re: What is the best Natural Gas Heater for a 750 SF pool?
    Raypak seems to be the most often recommended heater on the forums ... The bigger the better as it will heat faster.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Everyone around here, and seemingly everywhere appear like Raypak the best overall. I'm getting one for this reason, so I am hoping it loves up.
    Essential Links:
    Pool Tool's Avatar
    May 2014
    Western Chicago Area, IL
    757
    Patrick - any let down with the Raypak after a season's use? Thanks
    16' x 32' (21100 gal), vinyl, 1.5 hp Hayward SuperPump,
    Tagelus TA60/60D Sand Filter, Raypak 399K Digital Heater, TF-100
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Another plug for getting the largest heater (in BTU's) that your current gas configuration will support. It takes a given number of BTU's to heat a given water volume to a target temperature. A larger heater will do the job faster while not using any more total BTU's (vs. a smaller heater) to heat the water to your target temperature.
