Thread: Approximate cost per month--Natural Gas Heater
    Feb 2014
    Jersey side of Philadelphia
    93
    I'm looking to install an approximate 750 SF freeform pool 3.5 to 8 ft deep. I'm guessing that this is in the 37K gallon range, right?
    Where I live, the temperature at the beginning of June is about 80 for for the high on June 1 with about 60 for the low averaging 70 degrees. If we would like to occasionally heat the pool over the course of the month to 82 degrees, what is the approximate cost per day to increase the temperature to 82 degrees for an appropriately sized natural gas heater?
    Feel free to state you experience with natural gas heaters. Thank you.
    38,521
    Re: Approximate cost per month--Natural Gas Heater
    Depends on the cost of your gas. It takes 1 BTU to heat 1 pound of water 1 degree F. Calculate the mass of your water and then determine the number of degrees you want to heat it to give you the asking of BTU it will take. Although this ignores losses to evaporation and radiation to the environment.
    Short answer for your pool is a lot of $
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Our own Bo Darville has a really nice spread sheet he built for this, but I can't find the file. It really is nice, and very thorough.
    Perhaps he will be along and share it with you.
    In the meantime, here is a link to a website with a calculator for figuring that up:
    http://noanderson.com/services/swimm...re-calculator/
    Essential Links:
    Feb 2014
    93
    Quote Originally Posted by Brushpup View Post
    This is great. Thanks so much
