Results 1 to 10 of 10
Thread: Travertine
    Travertine
    Pool specs
    Live in Houston
    20000 gal
    Pebble tec surface
    Water chem normal
    Water is supplied from a water softener home system
    My problem:
    I have travertine coping that is 3 years old and has lost its luster, it was not sealed after installation( 1st time pool owner and contractor did not recommend). The travertine in spots has white streaks but overall does not have the the glossy brown as when it was new. It looks great when it's wet..wish I could keep it that way. What can I do to get that look back
    Thank you
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Travertine
    I wish I could help, but don't even know where to begin on that. Maybe someone else has dealt with this.
    Sorry I don't have more to offer, but I wanted to say welcome to the forum.
    Glad you found us.
    Essential Links:
    Vegas Kid's Avatar
    Dec 2013
    Cypress TX
    187
    Re: Travertine
    Why are you using a water softner for the pool? Your chemistry must be all over the place..
    Have you tried brushing the travertine with a brush every day for a week or so? Might just be a build up of dust on the stone.
    Also, natural travertine shouldn't "shine" unless you seal it. IMO, the natural stone is the perfect look anyways.
    30,432
    Re: Travertine
    Welcome to the forum.
    It could be a couple of things...
    1. There was a finish of some sort applied by the manufacturer that has since worn away and needs to be rejuvenated.
    2. You may have mineral deposits (from splashout) that have dulled the look you want. You can test for that by cleaning a small spot with a 3:1 ratio of muriatic acid and water, then rinse right away. If the look is restored, you will have to clean the entire surface and get a better grip on your water chemistry to prevent reoccurrence
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Travertine
    Quote Originally Posted by Vegas Kid View Post
    There is nothing wrong with using a softener for top-off, or partial fill. The key is proper testing, and knowledge of what constitutes good water balance for the pool. If the softener can meet the demand, it can be very beneficial in obtaining that balance.
    Essential Links:
    Vegas Kid's Avatar
    Dec 2013
    Cypress TX
    187
    Re: Travertine
    Quote Originally Posted by Brushpup View Post
    Good to know. I was under the assumption that it would be problamatic if used with an SWG system. I'm putting in an SWG so would using my water softner help with minimizing the chemicals or does it really just depend on too many other factors in the chemistry.
    NoFear95's Avatar
    Mar 2013
    Phoenix, Az.
    138
    Re: Travertine
    Sounds like it needs some cleaning.
    IG, 18K gallons, 100' Perimeter, 565 SF surface area, 980sf interior area, Max Length -36', Max Width - 16', Pentair 520 Clean and Clear Cartridge Filter, Stenner Chemical Injection System (Chlorine, Acid Coming Soon) , Pebble Tech - Blue Granite, Pentair variable speed filter pump, Zodiac MX8 Cleaner, Multi-Colored LED Lighting, Travertine coping & Decking, Boulder Water Fall....
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Travertine
    If you wouldn't mind, could you please open a new thread about this with your questions? I will answer any I can there so we can
    avoid hijacking this one any further.
    Essential Links:
    pragmatic's Avatar
    Jul 2011
    Friendswood, TX
    521
    Re: Travertine
    1st try pressure washing. If that doesn't help, test a small section and use HCl (muriatic acid); an all plastic spray bottle works best. Use caution with the HCL and rinse the area well after applying.
    Dec 2013
    East Texas
    87
    Re: Travertine
    I don't have travertine around my pool, but I do have a similar problem with marble tile in my bathroom. Both marble and travertine can be etched by acidic substances. In my case, it turns out the cleaning lady was using scrubbing bubbles which is acidic - and it says not to use on marble on the can warnings (oops). The marble has turned dull and lost all its shine, similar to what you are describing. Definitely try to clean it first with non-acidic cleaners, especially those specifically made for travertine. If that doesn't work and it looks like you have etching, get ready to spend a lot of time with expensive stone polishing compounds and a buffer...
    30X40' free-form gunite/plaster pool, 4-8' deep with flagstone beach entry, gunite "rock" retaining wall with multiple small waterfalls/planters, grotto/slide/waterfall combo, 18" raised spa with waterfall into pool
