Thread: Backwash valve leaking?
    Jun 2013
    Southwest Arizona (Yuma)
    125
    I have a plunger type backwash valve. I just did a backwash the other day and now I noticed it's leaking from the top. Is there a rebuild kit for this? If so, can someone help me out with the PN#? If not do I have to replace the whole valve?
    JB
    My pool:
    Built 2004, 14K gal, IG plaster,Pentair WhisperFlo 2 HP pump(1 speed), Pentair FNS Plus DE filter,
    In Floor cleaning system, Attached Spa with Spillover seperate WhisperFlo pump for jets.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Re: Backwash valve leaking?
    There is probably a rebuild kit, which is just a bunch of O-rings. You'll need the brand and model number most likely. If you can't find that, take several pictures of it and post them here, someone might recognize it. Then google it adding rebuild kit and you should get plenty of hits. You'll need a tube of pool lube to go with it.
    Jun 2013
    125
    Thanks Richard I will do that
    My pool:
