Thread: Replacing Controller - Where to Start?
    Dec 2009
    San Antonio, Texas
    78
    Our current controller is a Fiberstars WPC-2 and while it works okay normally, I don't care for the air temperature sensor-based freeze protection. I've considered upgrading my panel in order to get a water temperature-based sensor, but my pool company's recommendation for a $2000 replacement left me cold. (Sorry.)
    Our needs are pretty basic, I thought - remote for the light and waterfalls, and clock timer for pump scheduling, plus water temperature freeze protection.
    Recommendations for specific panels would be fine, but I'm really looking for a starting point in order to research the issue and compare features. Can you point me in the right direction, please?
    Jaywalker
    In-ground, 11,000 gallon, plaster, in-line trichlor pucks or BBB bottled chlorine, 1.5 HP pump @ ~100 gallons/minute, cartridge filter
    38,321
    Re: Replacing Controller - Where to Start?
    I thought all automation systems used air temperature for freeze protection
    poolkid's Avatar
    Mar 2012
    Mesa, AZ
    77
    You might consider the Z4 system from Jandy/Zodiac. You can buy it with or without the wifi antenna to connect to your home network.
    APSP Certified Building Professional
    APSP Certified Service Professional
    NSPF Certified Pool Operator
    Dec 2009
    San Antonio, Texas
    78
    That had not occurred to me. I like my pool company for repairs, and when they said everything else they worked on was water-sensored, while mine was old, I assumed that technology had passed me by.
    poolkid, I'll look at the Z4, thanks.
    Is there any basic controller 101 info I can review?
    Jaywalker
    ps0303's Avatar
    Jul 2011
    FL
    3,701
    The freeze protections are based upon the air temperature. For a very basic system you could go with a Pentair Suntouch. However, if you current system has the breakers inside the control panel, which I'm pretty sure it does, you will then need to find a similar system so you can remove the old control box and mount a new one with the breakers in it. This is probably what your pool company quoted you for $2K.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Dec 2009
    San Antonio, Texas
    78
    Quote Originally Posted by ps0303 View Post
    They quoted for the Hayward E-Command 4 (HPC-4-ACT_RC) plus installation.
    The problem is that I asked for the quote based upon my belief that I needed a water-temperature-sensor-based system; the old one is working okay. Since I don't need to move away from the air-temperature-sensor-based system, then I have no need for a new panel.
    I say the old one is working okay, but I don't know what temperature kicks it on (though ice does close the circuit), and based as it is in a warmer panel box against my house, the temperature probably reads higher than ambient.
    So - nice save, folks. I'll revisit when the control box gives up completely. Thanks.
    Jaywalker
