Thread: Vac port quandary
    May 2013
    Freeport, Bahamas
    14
    Vac port quandary
    Hey all, I have a query regarding a plumbing fitting. Is there such a thing as a fitting that goes INSIDE a 1-1/2" pipe that can take the regular sized vac port. My pool has been a nightmare since day one, the "Pool Contractor" connected 1-1/2" stub out for the dedicated vac line and the only inside fitting I can find is 2". If it's available great, if someone can point me to a retailer that would be even better.
    17,000gal IG, Diamond Bright finish, Ecostar SP3400VSP, Hayward Starclear plus C900 90sqft Cartridge filter, Aquarite SWG with T-9 Cell, Built/Completed May 2013
    22,544
    Re: Vac port quandary
    Most vacuum hoses fit right inside of a standard 1½" pipe. Can you post a pic of the type and style that you have or need?
    There are wall fittings that will slip inside a 1½" pvc pipe.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Break out a tape measure and head for the plumbing aisle of the local hardware store. I found a threaded-to-glued PVC adaptor the right outside diameter and a bathroom sink drain tailpiece that screws right in.
    May 2013
    Freeport, Bahamas
    14
    Quote Originally Posted by Bama Rambler View Post
    I would like to have the vac port installed for safety reasons (should the valve get left open i don't want any incidents!!) See the pics of what I have and what I would like, I have assembled it with a 2" off-cut but obviously I need it to be a fitting for 1-1/2" pipe.IMG_0987 (Large).JPGIMG_0982 (Large).jpgIMG_0988 (Large).jpg
