Thread: Freeze guard appears to be working properly, but
    Feb 2014
    heath, tx.
    1
    We are experiencing record cold temps here in the DFW area. My freeze guard appears to be working properly, cycling pumps on and off, however my spa is emptying into my pool and refilling. It appears to do this while my pumps are cycling on and off. Is this normal? Thanks, TJS
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: new pool owner
    Welcome to TFP!
    If your spa is emptying (draining) into the pool while the pumps are off, the most likely culprit is the check valve. The purpose of this valve is to prevent the water from draining back into the pool when the pump is off. I recently had this problem and had the check valve replaced. Problem solved. This is a relatively easy fix as the check valve should be easily accessible.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: new pool owner
    Looks like Bo got you something to look at, so I'll just say welcome to TFP!
    Essential Links:
