Thread: How to test Sta-Rite SR400NA Heater Blower Motor??
    Question How to test Sta-Rite SR400NA Heater Blower Motor??
    I have two SR400na heaters. One is older and only runs on 120v the other has the plugs in the control box that let you switch out to run 240v (Red plug) or 120v (black plug).
    On the old style the blower motor only has three wires going to the blower motor: White, Black, and Green. I wired a plug from an outlet and hooked up the white to white, and black to black and the blower motor came on. Test complete.
    On the newer heater the blower motor has a six wire plug: White, Black, Green, Yellow, Red, and Blue. Is there a way I can test this motor seperate from being connected to the rest of the system by wiring it to a plug like I did with the old style motor? Or how do I test the blower without it being installed into a pool yet?
    My goal is to use the most updated parts that are in the best condition to make one good heater and then know what parts are still good for spares incase something goes wrong down the line.
    Jeff
    36,000 gallons
    21 X 40 Grecian vinyl inground
    27 yr old hayward 1hp pump
    27 yr old 36sqft DE filter / multiport valve
    2 surface skimmers / 1 bottom skimmer
    3 return ports
    Jun 2012
    western NY
    1,559
    Re: How to test Sta-Rite SR400NA Heater Blower Motor??
    Removed inaccurate information
    ps0303's Avatar
    Jul 2011
    FL
    3,684
    The six wire plug allows for the motor to run on either 120 or 240. There is usually a wiring diagram located inside the unit to reference for troubleshooting. Look at it and I'm pretty sure it will identify which wire is what on the motor.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    http://www.pentairpool.com/pdfs/MaxEThermEng.pdf Page 30 has the schematic. You'd have to sit down with an ohmmeter and the proper jumper to figure out what feeds what. Even that is dicey. In short, I'd say the answer to your question is no.
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,691
    This is from Pentair. I won't comment on how to hook it up. Mainly because i haven't ever needed to test a blower off the heater. I suggest you plug the blower into the heater already hooked up to power and test that way. If you have a different plug, Pentair makes and ships with new blowers, a conversion plug. If you call them, they may sell/ give you one.
    Good Luck.
    Factory Warranty Station for:
    Thanks for all the feedback. I figured it wasn't going to be easy so i will take the advise of testing it once I get it all hooked up and installed into the system.
    Thanks again,
    Jeff
    36,000 gallons
    3 return ports
