Results 1 to 9 of 9
Thread: Connecting backwash piping to sewer
    Hi,
    I need to connect my new backwash pipes to our sewer - but the guy at the pool shop says I cannot connect it directly. He explained that I need some sort of air gap between the pipe and sewer - ie having the backwash pipe 20cm about the sewer grate ie it is not allowed to physically touch it. However, I cant have a pipe sticking 20cm above the ground where my sewer grate is in our yard - it will get in the way. Is there another way?
    Kind regards,
    Milan
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,100
    Re: Connecting backwash piping to sewer
    Where are you located? In many areas this is illegal to do.
    Sydney Australia
    22,553
    It all hinges on your local codes. If the code specifically calls for a 20cm separation then you will have to maintain that in order to comply with code. They may allow a double check valve and vent configuration but you'll have to check the local codes to find out the specific wording.
    Quote Originally Posted by Bama Rambler View Post
    What do you guys have in the States?
    38,463
    I think it varies greatly from hook up to sewer to do not even pump it out on the ground.
    22,553
    It all depends on locality here. From places that don't care, to places that require an air gap, to a complete double check with vent.
    I just have mine piped down the hill watering the trees.
    Sep 2012
    Lake Nona, Florida
    386
    I'd guess by "sewer" you really mean a storm drain? (eg grate in a yard collects water run-off, not actual household waste water).
    Here, I'm with bama - I direct the water towards the edge of my property and it gets picked up by a swale and into a ditch and off with the other water. Then again our soil is very sandy and a lot of water just goes away into the sand before getting anywhere.
    7500 gal gunite/stonescapes, iAqualink RS-8, Jandy 2HP VS-Flopro, Jandy 200 sqft Cartridge filter
    Pentair Intellichlor IC-40, Zodiac MX-8, Fafco solar panels
    DreamMaker X-500 Spa
    737mech's Avatar
    Jun 2013
    Corinth,TX
    148
    Our backwash for our de filter was run around to the front of our house to the sewer cleanout, not to be confused with the street storm drain.
    Finally completed March 2014
    IG 27,300 gal 35'x16' 3.5'/5.5'/8' diving pool, Pentair Intellichlor IC40, De FNS 60, 3HP Intelliflo VF pump, Easy Touch 4, Kreapy Krauly Platnium, 3/4 Hp booster pump, raised stone wall w/ 2 stone scuppers, Stonescapes aqua blue mini pebble plaster
