Results 1 to 9 of 9
Thread: Cold Water Effect SWG? And Salt Test Kit Recommendation...
    My SWG has a "cold water" notifier, which I assume means it will not generate FC at a certain temp (below 60 degrees F I believe). Is that standard or just a limitation of my SWG (Pentair Intellichlor fyi).
    Does cold water effect test results by any chance? I'm using Taylor's Sodium Chloride Test, but I know a lot of people use the test strips...any guidance on which is preferred and whether water temp would effect a test?
    PS: I was surprised to discover my salt level is low, hence the question.
    Thanks in advance!
    Ron
    22,551
    Re: Cold Water Effect SWG? And Salt Test Kit Recommendation...
    That is normal for most (if not all) swg's. The electrolysis process is affected at lower temps and typical home swg's have no way to compensate so they just shut down.
    I don't know how much the sodium chloride test is affected by temp but the swg's salt indication is significantly affected.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    Thanks, Bama!
    So, I can just switch to Bleach/Liquid Chlorine during colder months, correct?
    Anyone else have experience with the Sodium Chloride test?
    Ron
    Ron
    IG plaster pool; 14,800 gallons; Hayward 48 sqft DE bump filter; 1hp hayward super pump, polaris 9300 cleaning robot
    22,551
    Yes, just switch to liquid when it gets cold.
    Thanks again, Bama.
    FYI, to anyone following this thread, I just called Taylor and they confirmed the Sodium Choloride test is not effected by water temp as long as the range is between 40-90 degrees F. Just wanted to pass that along...
    Ron
    38,354
    I use the Taylor drop based test ... easier to note trends than with the strips. Although mine for awhile seemed to always read ~400ppm higher than the SWG and test strips. But, recently the test was matching the SWG ... weird.
    Thanks for the note about temp affects. I think the only test we routinely use that is affected by the water temperature is the CYA test.
    22,551
    Thanks, I'll try to remember about the salt test. I use it too.
    Thanks, Jason. The CYA test is only affected by very cold water though correct? I found this on Taylor's website:
    "Do pool or spa water samples have to be at "room temperature" before testing begins?
    With one exception, no. Our lab has run the pH, total alkalinity, calcium hardness, free chlorine, and cyanuric acid tests on known standard solutions at approximately 104F, 75F, 60F, and 40F. Only at 40F did the CYA standard solution test higher than its actual value (after accounting for test variability). All other tests were unaffected by temperature differences."
    Ron
    Ron
    38,354
    Right, we say let the water warm to room temperature before testing the CYA.
