Thread: Filter woes
    Jul 2013
    El Centro, CA
    3
    Filter woes
    So I'm in a bit of a pickle.
    I've got a pentair fns 60 DE filter that isn't filtering DE when I add it or very fine dust particles, which we get every time its windy here (2-3 times per week) so over the last few weeks my pool has gotten very dirty. The vacuum bag is too coarse to pick this up.
    I can hear air bubbles inside the filter and upon dissasembly, cleaning and inspection the only problem seems to be that the internal air bleeder assy is torn. The grids all look okay. Should replacing this fix my problem or is there more to it?
    Thanks.
    20k gallon, IG plaster, DE cartridge filter, 2HP single speed pump, Unkown build date (probably 70's), kleenmachine robot vacuum
    22,549
    Re: Filter woes
    It could be the problem, but that wouldn't pass a terribly lot of DE back to the pool. I'd tear it apart and not only inspect the grids very carefully, but also the manifolds and seals. It doesn't take a large tear in a grid to pass a lot of DE/dirt.
    Jul 2013
    El Centro, CA
    3
    Re: Filter woes
    You hit the nail on the head.
    I cleaned the filter and inspected the cartridges and there was a small spot on the bottom of one about an inch and a half long where the stitching had come undone. I restitched it with upholstery thread and my pool is now clean again. It was amazing how much dirty water passed through that small tear.
    38,285
    Re: Filter woes
    Nice work ...
    You really have to look closely at these things as you discovered.
