Thread: PVC Pipe Size
    Mar 2013
    CT
    349
    PVC Pipe Size
    Quick question - what is the "standard" PVC pipe size used in in-ground pool plumbing?
    Is it normally 2"?
    Thanks!
    Dan
    16 x 32 In-Ground vinyl, 21,000 Gallons, Hayward Cartridge Filter, Hayward Tiger Shark robotic cleaner, Taylor K-2006 Test Kit
    SW Georgia
    300
    Re: PVC Pipe Size
    I used 2" on most of mine, my main drain is 1-1/2. If I had to do it over again and the price was not to much more I might use 2-1/2".
    35K IG Vinyl 20 x 40 self built pool, Hayward Pro Series High-Rate Sand Filter 31" 98gal/min, Hayward TriStar 1.85hp, Hayward 400btu heater, BBB method w/Hypo, Jazz light w/matching fiber optic rope lighting around coping w/syncronized color wheels. Concrete Paver deck.
    30,414
    Re: PVC Pipe Size
    smaller pool = somewhat small pipe
    very large pool = larger pipe
    2" is by far the most common in an average pool.
    Feb 2014
    Upstate, NY
    390
    Re: PVC Pipe Size
    1 1/2 inch PVC pipe has been the "old school" standard for years. Today, It seems that 2 inch PVC pipe is the "norm" for most PB.
    20X36 IG vinyl (18,000 gal), 3 sheer descents, Max-Flo 1.5hp VS 2300, Aquarite T15 SWG, C3030 filter, 250,000 BTU heater, Sharkvac XL (Hayward equip)
    Nov 2011
    Moberly,MO
    1,010
    Re: PVC Pipe Size
    Alot of builders are going to 2.5" and in some cases 3" even for residential pools.
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
    38,267
    Re: PVC Pipe Size
    I can not see needing 3" or even 2.5" on a standard pool. Likely a good idea for spa plumbing and maybe large water features or maybe on a single suction line, but beyond that seems like overkill for the type of flow rates generally needed for strictly filtration.
