Page 1 of 3 123 LastLast
Results 1 to 20 of 58
Thread: New Pool Build - North Dallas in Allen (East)
    Dec 2013
    North Texas
    90
    Hello! I came across this website and forum over a month ago and it has been extremely helpful in my research on building a pool. I appreciate everyone that contributes to this forum as it significantly helps people like me who do a lot of research. Thank you to those that have helped me through PMs over the past month.
    Well, I have finally come to a decision after interviewing and going through two meetings with six different PBs. It was painful at times, but extremely insightful and, at the end, gave me a lot of leverage as I narrowed it down to the final two.
    Here are the general specs (edited):
    Freeform IG gunite diving pool
    Size: 18' x 40'
    Pool Perimeter: 104 lin. ft.
    Spa Perimeter: 22 lin. ft.
    Area: 654 sq. ft.
    Depth: 3'6" x 9'
    Gallons: 30,656
    Spa: 7 ft. circle with 6 jets
    Tanning ledge with 2 bubblers
    Two benches in deep end
    Deck: 504 sq. ft. Roman Slate textured
    Coping: TN flagstone
    Interior finish: Stonescapes (either Tahoe Blue or Midnight Blue)
    Water feature: stacked stone raised wall (two levels 9" and 18") with three 12" scuppers
    Salt diving board
    Equipment:
    Pump: Pentair IntelliFlo VS + SVRS
    Filter: Pentair Clean & Clear 520 Cartridge
    Heater: Pentair MaterTemp 400k
    Blower: Polaris QT 1.5 HP
    Cleaner: Pentair Prowler or Kreep Krauly Platinum
    Sanitizer: Pentair IntelliChlor IC60 SWG
    Chlorinator: Rainbow 320 Chlorinator
    Lights: 2 LED in pool and 1 in spa (either Pentair or ColorLogic)
    Control box: Pentair EasyTouch 8
    Automation: Screenlogic2
    We still have to finalize some of our selections (tile, finish, stacked stone, etc.), but we can do that over the next couple weeks during the permit process.
    Questions:
    Cleaner: I am having a hard time choosing (robotic or pressure). Any suggestions on a cleaner for a pool this size?
    Lights: Pentair IntelliBrite or ColorLogic? Does the ColorLogic integrate with the Pentair EasyTouch?
    Does everything look okay so far? Am I missing anything?
    I have a meeting with my PB to sign the contract tomorrow! I will upload design pictures soon.
    Killer95Stang's Avatar
    Sunny SoCal
    591
    Re: New Pool Build - North Dallas in Allen (East)
    Everything looks good... except the Rainbow 320... its not needed when you already have the Salt Water "Chlorine" generator. Also, if not not required, you should switch out the SVRS for a standard Intelliflo VS. My take on the LED lights.. stick with Pentair Intellibrite, since you are already going with Pentairs Automation system. Also, get a full sized Intellibrite for the spa... ie.. 5G instead of spa 3G fixture. LED's aren't as bright as halogen lights, so the extra light looks better... especially with colors like red or green.
    Pool done!! (backyard = work in progress) 32' x 19' inground freeform with 7' spa, baja step w/ (2) bubblers, stonescapes mini pebble finish, rock waterfall feature, 12" raised bond beam, Intelliflo VS, Whisperflo feature pump, (3) 5G Color LED's, FNS + DE 60, 400K Master Temp, Easytouch 8 w/ remote, Intellichlor IC40, Vision Classic Ceramic Kamado smoker, Margaritaville DM1000!!! Party Coming Soon!!
    TF-100 Test Kit w/ Speedstir
    bhargraves's Avatar
    Nov 2013
    North Texas
    183
    Congrats!! Looking forward to seeing the pics!
    Build Complete! : 111ft pool + 8.5x5.5ft spa (12" raised), ~22k gallons, Shotcrete, Stonescapes MiniPebble (Aqua Blue), 3 scuppers, 3 bubblers, Large Tanning Ledge, Long Bench, Pentair: Intelliflow 3050 VS, 1.5HP WhisperFlow (scuppers), Quad 100 DE filter, MasterTemp 400k, IC60 SWG, Intellichem+Acid Tank, 2HP Silencer Blower, travertine decking (~680ft2), dry stack flagstone raised wall / spa spillway
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,818
    I have a pressure vac with booster pump. I see no need to go with this setup. I think I would be equally well served by a robot. The pressure w/ booster is an extra piece of equipment, extra electric, extra noise, extra hose to wrap up and mine (Pentair Kreepy Krauly Legend) doesn't climb the slope very well. It always wants to circle back to the deep end regardless of the adjustments to the thruster nozzle. Thankfully we have an autocover and clean environment so the pool stays pretty clean by itself.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Dec 2013
    North Texas
    90
    Thanks for the replies and recommendations.
    I lean towards the robot as I have read they do a better job cleaning, but I know they can be expensive to repair and don't last as long. I still need to do some more research to find the right fit.
    Dec 2013
    North Texas
    90
    The contract is signed!!!
    I made a few changes:
    • Changed the deep end to 9' (reduced from 9'6"...I am scared of rock as my neighbor directly behind me hit rock on their pool)
    • Added a 6th jet and a second level to the spa
    • Lengthened the raised wall
    I thought the pool was perfect Tuesday night when I signed the contract...however, I received the revised 3D pictures today (see below) and I still have concerns about the raised wall not being long enough. It was 17' and I had him stretch it to 22' and thought that would be long enough. It is two levels, the first level is 9" tall and is 3'6" long on both sides and the second level (middle section) is 18" tall and is 15' in length. With the pool just under 40' the raised wall extends a little over half the pool.
    Let me know if the pictures don't show up.
    Maybe it is just the angle of the last picture, but it does not look long enough across the back of the pool to me.
    How does it look to you?
    My other concern is the layout. I tried to show my wife how it was going to fit in the backyard today did not look right.
    I called my salesman and he is going to send me some more pictures including one from directly above the pool and give me all of the dimensions to get me comfortable with raised wall and layout. He is being very patient with me...so far. I want to make sure we get everything right before we get too far into the permit process.
    Let me know if you see anything else in the design that does not look right to you.
    Build is Done!: 18'x40' diving pool, depth 3'6" x 9', 104' perimeter, ~24k gallons, spa (6 jets), raised wall (3 scuppers), tanning ledge, Pentair IntelliFlo 3050 VS+SVRS, Pentair Clean & Clear 520 cartridge filter, Pentair MasterTemp 400 BTU heater, Polaris QT 1.5 HP blower, Pentair Intellichlor IC60 SWG, IntelliBrite 5G lights, Pentair EasyTouch 8 with Screenlogic2, 504 sq ft Roman Slate textured deck, Aqua Blue StoneScapes finish
    Readyforapool's Avatar
    Sep 2013
    DFW metroplex
    738
    That's going to be beautiful! If money is not an object I could see where you might want to extend the wall but it's beautiful like it is.
    Finally Done! - 21x34 IG, SWCG, depth - 3.6 - 4.6 - 6.6, Pentair IntelliFlow 3050 vs+svrs, 60 sq ft Pentair DE Filter, 400k BTU Heater, Polaris 280 w/.75 hp booster pump, Pentair EasyTouch wireless, 38 sq ft raised spa, wet edge Barbados quartz finish - ODK w/36 in Napoleon grill
    bhargraves's Avatar
    Nov 2013
    North Texas
    183
    I like the design. I do think the raised wall would be better longer, but does not look bad the way it is. You could always compromise on height if budget was a concern with making it longer.
    You shouldn't worry about patience with your sales person. You are paying a lot of money, and if you're like me, this won't be the last time you change something. Make sure you are satisfied, and don't worry about what they think.
    For placement, I had them send me the 2D drawing, and then I imported it into a free SW program called Sketchup. Then I sized the picture to make the measurements in Sketchup match. Then I could use it to make measurements, trace / move the pool, etc.
    Dec 2013
    North Texas
    90
    Quote Originally Posted by Readyforapool View Post
    Thanks Readyforapool.
    bhargraves, how long is your raised wall? It looks like it is going to run along the majority of the back of your pool and looks really nice.
    I am definitely going to ask him to extend it. I am thinking it should run at least 3/4 of the back of pool.
    Another question: do you like the placement of the light in the shallow end? Would it be better under the tanning ledge pointing at the water feature? We do have a neighbor directly behind us...not sure if the light would bother them.
    Thanks for your help.
    Sep 2013
    DFW metroplex
    738
    My PB originally had both of my lights at the deep end and I had him move one to the shallow end near the tanning ledge - that way the whole pool seems to be lit.
    bhargraves's Avatar
    Nov 2013
    North Texas
    183
    I think my wall is about 38ft total. Pool length is 41ft. We did 6" stepping to 12".
    MiaOKC's Avatar
    Apr 2012
    Oklahoma City, OK
    347
    To weigh in on the cleaner question in the initial post, we have a robot. We'd talked about trying to revive our hardline port during our reno but now think we will just stick with the robot. If I had my choice, I'd have a backup robot (maybe not as fancy as my Polaris 9300 main robot) for when the main robot has to have repairs. It was a PITA to wait for parts and warranty repair for over a month - you get used to the luxury of dropping the 'bot in and coming back to a clean pool! My 35K gallon pool is in a very leafy area, so the environment will dictate the best robot for your usage, just make sure that the cord and reach of the robot is good for the size of your large pool. Ours plugs in on the porch and the cart stays there, and then the low-voltage line that runs the 'bot has to go across the deck and into the pool, so measure from the power source to the farthest reaches of your pool and make sure you have a little slack.
    35,000 gallon gunite pool, semi-T-shaped, 29x15 shallow end and 16x22 deep end, built in the mid-1970s and renovated 2013-2014 // Polaris 9300 Sport robotic cleaner // Taylor K-2006 ... Learning as we go and so grateful to everyone here for their help! Our reno thread
    Dec 2013
    North Texas
    90
    Thanks Mia.
    I would like a robotic cleaner because I have read they do a better job cleaning. My concern is they don't last as long and my PB won't plumb a return line for the pool if I go with a robotic cleaner.
    Per my PB, my options are:
    Pressure side cleaner - Polaris 280 with booster pump
    -or-
    Robotic cleaner - Pentair Prowler (or something similar)
    The reality is that the Polaris 280 would probably work just fine and I could always get a robot later.
    Decisions, decisions...
    Sep 2013
    DFW metroplex
    738
    We have the Polaris 280 and it's done an amazing job, took care of a lot of leaves and crapola that they dropped into the pool while trying to find the leak. Let me tell you that little puppy can move, had to rescue it from the skimmer when it climbed the wall! I'm sure there's some adjustment I need to make but at the moment since we can't swim, it does provide some pool entertainment! Seriously need warm weather!
    Dec 2013
    North Texas
    90
    It is officially off to the city and HOA for permits and approval!
    We made a few decisions:
    • Extend the raised wall to 30' in length (see the updated 3D pictures below)
    • Cap the existing patio with new decking
    • Polaris 280 cleaner
    • Keep the second light in the shallow end where it is to light up the entire pool
    I like the raised wall length better now.
    My sales rep sent me a drawing with all of the measurements so I could lay it out in the backyard to show my wife the foot print. We happy with the layout but we are going to have a little less side yard than originally thought...so now we are selling our jungle gym!
    After doing more reading on this forum and additional research, we are going to bite the bullet and finish out the backyard all at once instead of breaking it up over multiple projects. So, we are going to add more deck, put in an outdoor kitchen, do the landscaping around the back of the pool and get some quality patio furniture...the budget has been blown away now. The outdoor kitchen will be two heights and will include a green egg, grill and frig. We are adding more deck around the back of the outdoor kitchen for bar stools. It is way too easy to spend money with this project!!!
    Congratulations! It looks like you have done your homework and made some great choices. The raised wall really adds to the character of the pool.
    Oh Yea. You have a diving board!! Neat!
    Vegas Kid's Avatar
    Dec 2013
    Cypress TX
    187
    Very cool design. I also think the wall looks better now that it's longer, but looked fine before.
    I know you'll be excited once they start excavation.
    Nov 2013
    Oro Valley AZ
    99
    Looks great! I am feeling your pain about the budget, but it is going to look fantastic! I look forward to seeing the progress.
    bhargraves's Avatar
    Nov 2013
    North Texas
    183
    That is going to be fantastic! I think you made the right call on the wall length. It looks like it belongs more now and ties into the pool better. Hopefully you get the permits quickly and get rolling!
  20. Back To Top    #20
    Dec 2013
    North Texas
    90
    Well, I got a call from our PB yesterday to ask if this coming Friday works for our dig. I said yes, with a little hesitation because we don't have the permits or HOA approval yet. He said he is not worried about it and thinks we will get them this week. Any concern here? I won't let them start until we have the proper permits and approval.
    We have made a few decisions:
    • Neck Roll for the spa - thanks for the idea christopertx! Link to christophertx's neck roll
    • Small tile for the spa (upgrade...of course)
    • Waterline tile
    • Stacked stone for the raised wall and veneer on the outdoor kitchen
    • Purchased grill and refrigerator for outdoor kitchen (I bought it on Friday and it will be delivered on Monday!)
    Waterline tile and spa tile
    Raised wall and ODK veneer
    We went back and forth on the veneer choices 5 or 6 times.
    The A/V guys came to the house this weekend and explained to me the possibilities of Sonos! He thinks we should have three zones in the back (one for the TV and covered patio, one for the tanning ledge area and another one for the rest of the pool). It seems really cool as you can control the volume and play something different in all zones...all from your phone or tablet. He is going to send me the quote, but I think I will have the prewire the whole thing and have to do it in stages. This pool thing is expensive!!!
    Does anyone have Sonos and use it for their outdoor area and pool?
    I sold the playhouse/swing set! It sold for $500 (we paid $2,400 for it back in 2008). Now I need to sell my old grill. Any $$$ to go to the pool fund helps!
