Thread: mortar mix for pool surround
    aussieta's Avatar
    Jan 2014
    Langwarrin, Victoria, Australia
    488
    not sure if this is the correct section , mods feel free to move
    anyway a lot of the clay pavers around the pool and the coping the mortar has disolved/cracked
    i want to rip up and repair damaged areas
    is there a special mortar mix or type of mortar for around swimming pools
    thanks,
    Andrew
    SWG inground peanut shaped eco-bright concrete pool
    50,000 litres 13,000 gallons
    Lincoln Salt Chlorinator, 25 gram cell Sand Filter with glass media
    Taylor K2006-C test kit, Taylor K-1766 salt test, Dolphin M500 pool cleaner
    are you taking care of your pool or is the poolshop taking care of you
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: mortar mix for pool surround
    I could be wrong, but I really don't think so. Hopefully someone will confirm.
    Essential Links:
    Oct 2013
    Phoenix area
    91
    Type S mortar or look at some of the products from Laticrete i.e. 254 platinum having polymer fortified thin set.
    13,000 gallon IG
    PCC IG cleaning system
    Pentair equip.
    Attached spa
    Dire need for surface refinish!
