Thread: How to add calcium chloride
    So I have read two different ways to add calcium chloride. 1. Mix it in a bucket with water, but watch out that it doesn't, melt the bucket. 2. Put it straight into the pool, but be careful that it doesn't leave calcium deposits. Help! Advice please. Thanks
    27100 gallon in ground Pool/Spa, SWG, Pebble Sheen-Aqua Blue, (All Pentair Equipment) Pentair VS Pump, Cartridge- filter, build completed Dec. 2013, Houston, Texas
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Re: How to add calcium chloride
    Calcium products should be spread across the surface of the deep end of the pool.
    http://www.troublefreepool.com/conte...pool-chemicals
    Be sure to brush immediately, and thoroughly, if you broadcast calcium chloride. Have a brush ready as calcium chloride can harden very quickly on the bottom of the pool, especially if it's cold.
    Support the site
