Thread: Polaris plumbing
    Atlanta, GA
    31
    Polaris plumbing
    My booster pump is plumbed with Polaris brand flexible hose (3/4"). Is there a reason the installer didn't use rigid PVC?
    I'm getting ready to redo my equipment pad and wondering If hard plumbing would be better.
    24000 gal vinyl IG; CPSC36 SWG, TA-60 Sand Filter
    22,553
    Re: Polaris plumbing
    It's very common for the booster pump to be plumbed with the flex hose even if the rest of the system is plumbed with rigid pvc.
    I like rigid plumbing but it's not a huge deal for the booster pump.
    Atlanta, GA
    31
    Thanks. This is my first pool so don't have a lot of experience with different setups. I just wanted to make sure rigid PVC would be ok. That's how I plan to redo it.
    CUTiger78's Avatar
    May 2009
    NoVA
    460
    Well, the Polaris flex pipe & their fittings do make it easy to remove the pump for repairs. With PVC, you're probably gonna need a at least one union or be prepared to cut & repair, when necessary.
    My Polaris has had a couple of leaks at fittings and I also had to replace a cracked veloute over the past 20 years.
    The one you're most comfortable with is probably the best!
    Good luck!
    36K gallon 42X22 gunite/plaster kidney-shaped IG;
    1 hp Hayward Super Pump (new in 2012);
    Hayward S244T sand filter w/ Zeosand (both new in 2009);
    175K BTU LAARS Lite2 LG natural gas heater; Polaris 380;
    TF-100 test kit.
