Results 1 to 10 of 10
Thread: Soon to be new pool owner question about speed stir
    Jan 2014
    Chandler, AZ
    8
    Hi All, This is my first post but I've been lurking for about a month, reading a lot of threads, reading and re-reading pool school. This is such a great site and an amazing community of knowledgeable and helpful folks. Thanks!
    In about 10 days I will be a new pool owner and I am ordering a TF-100 test kit. I'd like to get some opinions on the speed stir. Do most find it helpful or find that it's easier to just swirl the cylinder when adding the drops? I'm sure I'll have more questions once we move into the house and I get my first set of test results.
    9100 gal (est), Pebbletec, Ecomatic ESC 36 SWG.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Welcome to TFP toddb !!
    The speed stir is a handy thing to have. I have one and love it. It beats swirling.
    Good job on getting one of the best test kits !!
    Jeff
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,095
    Re: Soon to be new pool owner question about speed stir
    Welcome to the site and congrats on your new pool!
    The speedstir is a HUGE help on many of the tests, and a lifesaver come the calcium test. Having the sample stirred the entire test allows you to closely watch for the color changes in the water sample. For just over $30 you won't regret it one bit. Check out the video on TFTestKits page.
    http://youtu.be/4_EJknrPjYE
    mikespoolfl's Avatar
    Mar 2011
    Florida
    179
    The best way to get good consistent readings. I had mine for at least 2 years.
    Screen enclosed 17K gal 16x30 IG with Diamond Brite finish, elevated 4 jet spa with spill over, Twin dolphin fountain, Hayward Ecostar pump[ Pentair intelliflo VS, Filter Sta rite Posi-Flo PTM 100, Aqua Cal heat pump, Tiger Shark QC robotic cleaner.
    Stenner peristaltic pump model 45MPHP10, 15 gal storage tank. TF 100 with Speed Stir.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    I wish I had one. A few times while I was testing I was swirling the tube by hand. Guess I got a bit agressive and swirled some of the water in the tube right out of the tube. So, had to start over and do it again. A speed stir is on my 'must get' list before it gets swimming time again.
    Divin Dave,
    wjr75's Avatar
    Jun 2013
    IL
    836
    Yes get one!
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    Jan 2014
    Chandler, AZ
    8
    Speedstir it is then. Thanks for the feedback everyone.
    Mark R's Avatar
    Nov 2013
    Desert Southwest, USA
    166
    Agree, you'll love it
    12k gal Gunite/Hayward filter C5520BH with quad 33 inch filters. 2.5 hp motor. Pool is on south side, so full sun light. Spill over spa.
    Laar's heater LT250-Low NOx Gas Fired for pool/spa 250,000 BTU. Roof mount 6 panel solar system installed east/south. TF-100 test kit. May-September 100+ degrees out side.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    First, welcome to the forum!
    Congrats on getting started in the right direction too. Knowledge and testing is what it takes to have a perfectly balanced pool.
    Get it, and you will never regret it. A little to the cost, but a WHOLE LOT of help. All labs use similar devices when running Titrations, because they are such a tremendous help.
    Essential Links:
    Mar 2010
    Spring, TX
    1,082
    I agree Get it as it seems you have already decided to get it.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
