Page 1 of 2 12 LastLast
Results 1 to 20 of 32
Thread: New Pool Build Rockwall, TX
    Hello All,
    After many days of lurking on this site I have started our pool here in Texas and decided to post some pics. Through this forum I was able to make a few decisions and read some good advice from fellow members. We went chlorine due to our builders advice and what I have researched. We will see how that goes. Anyway, these are current as of 1/31/2014. More pics to follow.
    17 by 32 free form gunite
    3.5 to 4.5 to 4ft deep play pool (14,500 gallons)
    sundeck with 2 bubblers and two benches in pool.
    Brass sleeves for volleyball net
    Sand colored textured decking (640 Sqft)
    Oklahoma flagstone coping with noble tile at the waterline
    Aqua blue plaster from stonescapes.
    2 speed variable pump
    chlorine
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: New Pool Build Rockwall, TX
    Welcome to tfp, flyingboxes
    Looking forward to your progress!
    Casey's Avatar
    SW PA
    10,444
    Welcome and keep the pics coming! Good luck
    Mar 2013
    New Hampshire
    351
    That is some very tight work conditions for that machine.... Is that a road on the other side of the fence? Are you planning on putting a privacy fence up when completed?
    Good luck with the build.
    18k: IG: Black Granite Liner: Aspen: 16x33.5: SWG: Polaris 280
    My pool build new-pool-build-in-nh-t60957.html
    Hi, no road. It is about a 3 foot drop off with a retaining wall. The fence must remain metal in the back because it is a "green zone" according to the city/HOA. It is a small pond, It does look like a road though now that I look closely at the pic.
    Im trying to post more pictures but it wont let me! How do I get more than 2 pics on here?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Welcome to the forum! Nice build!
    Essential Links:
    Ok, finally figured it out. Looks like photobucket is the way to go.
    We are at the gunite stage now. Waiting for it to cure for 7days.
    Next is tile and coping.
    A few more as of today.
    looks like a great pool for the family!
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Looks like an awesome pool !! Keep the pics coming !!
    Jeff
    Well I thought they would wait for the curing until doing the tile and coping but no....they are here gettin it done!
    No work today, the cold has brought things to a standstill.
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    Wow the Snow went from one side of the state to the other.
    There's got to be quite a few pool builders bored today.
    IG gunite/plaster pool/spa Started 1/17/14, Plastered 5/16/14
    Size: 12'-21'x39' free form, depth ranging from 4' to 7, attached 6 person spa with spillover.
    Equipment: Whisperflo 2hp pump, Pentair 30" sand filter, Pentair Mastertemp 400k BTU heater, 1hp Whisperflo for waterfalls, and a blower for spa floor
    Yep, today as well. More snow flurries!
    17x32 free form Gunite
    IG 15000 gallon
    Chlorine Cartridge filter
    Variable speed pump
    Built/building Feb 2014
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    We got off easy on this side of the state. We're dry again, supposed to get to upper 40's.
    Good luck!
    Dec 2013
    North Texas
    90
    This weekend should be a little better and get up into the mid to upper 50s in the DFW area!
    Build is Done!: 18'x40' diving pool, depth 3'6" x 9', 104' perimeter, ~24k gallons, spa (6 jets), raised wall (3 scuppers), tanning ledge, Pentair IntelliFlo 3050 VS+SVRS, Pentair Clean & Clear 520 cartridge filter, Pentair MasterTemp 400 BTU heater, Polaris QT 1.5 HP blower, Pentair Intellichlor IC60 SWG, IntelliBrite 5G lights, Pentair EasyTouch 8 with Screenlogic2, 504 sq ft Roman Slate textured deck, Aqua Blue StoneScapes finish
    More work in between crummy weather, decking to follow...maybe tomorrow??
    IG 15000 gallon
    Variable speed pump
    More work done this past week. Deck pour. One week for the acid wash, retaining flower bad walls to be built this week, sprinkler system re routed....plaster and water to follow!
    IG 15000 gallon
    Variable speed pump
  20. Back To Top    #20
    Deck cleaned off......plaster next.
    IG 15000 gallon
    Variable speed pump
