Thread: Will lubricant cause a rust looking stain and what ground screw on intellibrites?
    Oct 2013
    Southern California
    69
    I just read this thread. They are installing my intellibrite 5g color 120v lights right now. They are using a wire pull lubricant, which has dripped onto my shotcrete too, and I am worried that it will cause stains after reading this thread: http://www.troublefreepool.com/threads/39754-Rust Will it? What should I do. Also, do they use the stainless steal grounding screw or the bronze one? The bag the ss screw came in said to use it on a new pool (which we are doing), but the manual said to only use the included bronze screw. Which do i use??? Please help me and tell me if I should tell them anything asap. Thanks so much.
    Last edited by Angnjam; 02-01-2014 at 12:57 AM. Reason: No longer urgent and title change
    24k gallon 16x38 IG shotcrete pool + 5x10 tanning shelf, Stonescapes Tropics Blue, Heat Siphon Z575HP Heat Pump (11.45 KW PV SunPower Solar), Pentair 3HP VS Pump 001018, Pentair SWG IC40, 2 Pentair IntelliBrite 5G 120v color LED pool lights, Pentair IntelliGlo 5G 12v color LED shallow water light w/300W transformer, Pentair DE FNS Plus 60sf filter, 24" rbb wall, 3.5-7' depth, TFT100 Test Kit, K1776 Salt Test kit, '07 Sundance Chelsee spa
    22,548
    Re: Urgent! Will wire pull lubricant for intellibrite light cause a rust looking stai
    Which wire lube did they use?
    They should use the stainless steel one.
    Oct 2013
    Southern California
    69
    Okay thank you. Good because that's what they are using, but I guess it doesn't get grounded until after plaster. Does anyone know why the stainless steel one is used on new pool builds and the bronze one is used on remodel! That doesn't make any sense to me. The guy from Pentair didn't know why they do this either. The lubricant they used is this one image.jpg
    image.jpg. And does this light install look correct? Do they not have to seal where the wires go to the sub-panel? The sub-panel is above the pool so I guess water won't travel to the connection on the other end.
    22,548
    Re: Will lubricant cause a rust looking stain and what ground screw on intellibrites?
    That wire lube shouldn't cause any problems.
    The conduit doesn't get sealed. The water will rise up in it but it's sealed to the niche so it won't leak.
    The new niches are designed with materials that are compatible with stainless steel so you use that screw. Older niches may not be compatible with stainless steel so you use the brass screw. They started using stainless steel due to the increased popularity of swgs.
