Hello Everyone,
I have the skimmer type that has the basket that floats up and down with the water level and am in need of a solution to a problem. The floating section tends to get stuck in the "up" position if we get a lot of turbulance in the pool such as playing, heavy winds, or if the water level gets too high. When it sticks, the skimmer starts sucking air because the water level is below the floating section.
Has anyone else had this problem and found a good solution?
Thanks.
Thanks.
