Results 1 to 12 of 12
Thread: This pool is crystal clear even in a flood.
    Not my pool. Click the image for the full article. Hopefully the link works, I have trouble with these "photo blog slideshow things".
    20,000 gal in-ground plaster pool with sand filter. Replastered recently. Mostly adding bleach and acid. CYA was high when I took over.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: This pool is crystal clear even in a flood.
    That one was posted when the flood was happening a year or two ago, as I recall it is in Europe
    edge's Avatar
    Mar 2014
    Douglas, GA
    143
    I see the flood didnt quite get high enough. Cool picture. Def one in a million
    Mar 2014
    London
    2
    A beautiful contradiction of terms.
    skylar18's Avatar
    Apr 2013
    Austin, Texas
    299
    With the plastic furniture I see, and I am suspicious by nature, is this picture a photoshop trick?
    43 x 19 Gunite Pool w/ spa and fire pit, 19,000 gallons, Pebble Sheen Aqua Blue finish, Jandy 2 HP VS E-pump, Jandy 580 sq ft Cartridge Filter, Jandy LXI 400k Heater, Jandy Aquapure 1400 SWCG, 4 Jandy LED color lights, Aqualink PDA and Iaqualink, Polaris 280 with Booster Pump. Polaris 9550 Robot Cleaner. 1 HP Silencer Air Blower for Spa http://www.troublefreepool.com/threa...NAL-INSPECTION
    edge's Avatar
    Mar 2014
    Douglas, GA
    143
    Possibly of course however if the flood wasn't Swift and say the water slowly rose. The furniture wouldn't necessarily go anywhere.
    They must be using the BBB method...
    16'X32'X8' Vinyl Pond with Diving Board (Neck Breaker), 1.5 hp FOXX WhisperFlo(Not so quite anymore), Massive Lawn Egg (aka: Sand Filter), Coolcrete Pool deck (Burns feet to a crisp), Large wooden Multi level deck (Splinter City) with fire pit in center (Insurance company's nightmare.)
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    if its a photoshop, its a good one. If you look at all of the shadows of the pool and everything else, the angle on all of the shadows are the same and in scale.
    I personally think its real.
    Divin Dave,
    I would lean to photoshop. It only has a small skimmer. No jets and no main drains. Couple of other flags on this play.
    Mar 2007
    San Rafael, CA USA
    12,082
    Above-ground pools usually do not have main drains. Having one skimmer is not unusual (I only have one for my 16'x32' in-ground pool) and there may be multiple inlets. It has realistic features including a Trichlor puck floating dispenser and a pool cover that is offset on its reel to easily go around the ladder (i.e. unspool it then move it over).
    Jan 2013
    Houston, TX
    1,079
    It's actually a Reuters photo of the year for 2013 taken in Germany. If they guy that won it did photoshop that together his career is on the line. My .02 ... Legit
    TFP Moderator Chris V. ~16K Pool & Spa, 48NSF DE, IG Plaster Circa 2000, Intermatic PE653, Challenger pump with a 2 speed B2984, 20gal stenner chlorine injection, Houston, TX
    One cannot follow Islam and Christianity at the same time, nor can one follow pool store methods and TFP at the same time.
    Pool School -- Pool Math -- TF-Test Kit
    Now I see, I was thinking it to be a in ground. This would explain my other question why it didn't flood while the water level was up a foot on the benches.
    34,000 gal, IG vinyl lagoon shape, Pentair intelliflo varible speed 3hp varible speed pump, 2hp varible speed sheer descent pump, 520 clean an clear cartridge filter, letro legend with booster pump, 8ft bench with two 3ft sheer decents, 3 Pentair Magic Flow Laminar Jets, Intellibrite 5g led lighting, Build currently in progress
    JoshU's Avatar
    New Orleans, LA
    543
    CNN used it as photo # 5 in this gallery: http://www.cnn.com/2013/06/11/world/.../europe-flood/
    Josh Ulfers - josh@saltpoolguys.com - 888-725-8766
    SaltPoolGuys.com - AutoPilot Pool Pilot Systems, Parts & Cells - AquaCal Heat Pumps
