Results 1 to 7 of 7
Thread: Sand Filter Brands - Pros and Cons?
    Atlanta, GA
    31
    I have been happy with the filtering performance but need to replace my Tagelus TA-60 due to a leak in the tank.
    I will most likely replace it with a filter/multi-valve combo so am wondering if you guys can weigh in on brand preference and why you like what you like?
    Price is certainly a big consideration but reliability/ease of use might outweigh cost if there are big differences between brands.
    Thanks
    24000 gal vinyl IG; CPSC36 SWG, TA-60 Sand Filter
    38,305
    Re: Sand Filter Brands - Pros and Cons?
    If you stick with the major brands, then I am not sure there is very much difference between them.
    After all it is just a big bucket of sand
    22,551
    If you're happy with the Tagelus, I see no reason to change. The only suggestion I'd make is that I'd go with the TA-80 for a pool your size.
    Atlanta, GA
    31
    Thanks for the responses guys.
    I agree on the tank; brand probably doesn't matter. I was asking more about any differences in the valves or internal components between brands.
    For example, Sand Dollar SD-60 is available with or without "Clear-Pro Technology". Is it worth the $50 difference in price?
    Also, thanks for the suggestion about upsizing. If I do that, are there any issues operating with the same size pumps and motors?
    Aug 2010
    Dallas, TX
    4,052
    I'd have gotten the clear pro (at least the Pentair version) for mine if it were available - just as an experiment. But, for my filter's size, they don't make it. But I have to say, my water is CRYSTAL clear right now, so I really didn't have any reason to want it.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    I am not sure pentair sells a TA80 now, they do sell the sand dollar line in a SD80. With that said, I would probably go larger and look at the TA100D which is in line with our recommended size for you volume pool. I do not believe that comes in a clear-pro version. In regards to the clear-pro technology, we have not had much user experience posted on here.
    22,551
    I wouldn't pay extra for the clear-pro.
    I have a SD-60 and am happy with it. I'd suggest going with the SD-80 or TA-100.
