Results 1 to 7 of 7
Thread: Changing shape slightly after permit is issued?
    Dec 2013
    Northridge, CA
    29
    If we decide to change the shape just slightly before the dig happens, will most cities require new plans to be filed? For example if we reduce the length by a foot or change a curve or something similar...
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    Re: Changing shape slightly after permit is issued?
    I doubt it as long as you don't get too close to any of the "no fly zones". For safest answer, ask your city inspector. (my city doesn't care as long as you don't try anything sneaky).
    IG gunite/plaster pool/spa Started 1/17/14, Plastered 5/16/14
    Size: 12'-21'x39' free form, depth ranging from 4' to 7, attached 6 person spa with spillover.
    Equipment: Whisperflo 2hp pump, Pentair 30" sand filter, Pentair Mastertemp 400k BTU heater, 1hp Whisperflo for waterfalls, and a blower for spa floor
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Each locality has its "quirks". Best to ask your building inspection dept. Usually a phone call most places I've dealt with are pretty fair.
    Sep 2012
    Lake Nona, Florida
    386
    If the change is still conforming there should be no troubles, and in the worst case would require an amendment to the plans. On other construction I've seen this done with handwritten notes and arrows. However as hinted with "no fly zones"... if you happened to violate a property line setback, or violate the angle of repose of an adjacent structure, it could get bad for you.
    In our case we added a step and changed some curves on the fly when they shot the shell. All inside the perimeter of the pool shown on the plans. The inspector never said a word about it. However, in other (non pool) construction we once made some minor changes to a structure and the inspector made us get a letter from the architect before OK'ing it. In the end it is often at the sole discretion of the inspector... so my policy to inspectors is to ALWAYS be friendly and polite, NEVER be evasive, but DON'T volunteer information they have not asked for.
    7500 gal gunite/stonescapes, iAqualink RS-8, Jandy 2HP VS-Flopro, Jandy 200 sqft Cartridge filter
    Pentair Intellichlor IC-40, Zodiac MX-8, Fafco solar panels
    DreamMaker X-500 Spa
    bhargraves's Avatar
    Nov 2013
    North Texas
    183
    We applied for permits, and then added a spa mid-stream. The electrical permits had already been issued. Our PB spoke with the city, and informed us they would not require re-permitting for electrical, and allowed us to submit the modified design drawings to the city while keeping our place in line. If you can get the PB to negotiate this, you may not have to re-do anything. But again, every city is different, so best to get your PB to close with the city's permit department.
    Build Complete! : 111ft pool + 8.5x5.5ft spa (12" raised), ~22k gallons, Shotcrete, Stonescapes MiniPebble (Aqua Blue), 3 scuppers, 3 bubblers, Large Tanning Ledge, Long Bench, Pentair: Intelliflow 3050 VS, 1.5HP WhisperFlow (scuppers), Quad 100 DE filter, MasterTemp 400k, IC60 SWG, Intellichem+Acid Tank, 2HP Silencer Blower, travertine decking (~680ft2), dry stack flagstone raised wall / spa spillway
    Mar 2013
    New Hampshire
    351
    We submitted a permit for a square pool as it was easy to draw on the plot plan the city required. There is nothing sq about our pool. They just cared about the setbacks and gates when they came to check it out.
    18k: IG: Black Granite Liner: Aspen: 16x33.5: SWG: Polaris 280
    My pool build new-pool-build-in-nh-t60957.html
    Definitely check with the inspector. Especially if you are getting a diving board.
    Support the site
