Page 1 of 18 123411 ... LastLast
Results 1 to 20 of 343
Thread: NEW Gunite IG pool - West Texas
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    This all began 1-17-14. The dig took 2 days.
    Rebar work started on 1/20/14
    more rebar work
    more pics Photobucket:http://s300.photobucket.com/user/mrc...an%2017%202014
    It's been bitterly cold so nothing has been done over the past 4 days.
    The basic specs on the pool are
    Size: 12'x21'x36' free form
    Depth: 4'-7'
    Decking: kool deck
    Pump: 2 pumps. One will run water features (more info later)
    Heater: natural gas 400k BTU(more info later)
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: NEW Gunite IG pool - West Texas
    Good to see another Westex native aboard!
    We'll look forward to seeing more on your build so keep us updated. Most of all, Good Luck!
    Essential Links:
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    Oh, Here's a little backstory on our backyard project.
    First, massive Elm had to be removed. We were also getting the exterior of the house fixed up at the same time...that's why the patio looks 1/2 finished.
    1/3 of it decided it wanted to get a closer look at the ground
    so I cut it off and killed a chainsaw in the process
    Paid people to cut the rest down, as the risk of death was fairly high if I'd have tried
    Electricity and cable were both rerouted -in this pic it's only the electricity...but you get the idea (it took us nearly 3 months to get Oncor to move the line).
    Oh, and the dogs area was moved back as well...you can see that in the progression of pics.
    IG gunite/plaster pool/spa Started 1/17/14, Plastered 5/16/14
    Size: 12'-21'x39' free form, depth ranging from 4' to 7, attached 6 person spa with spillover.
    Equipment: Whisperflo 2hp pump, Pentair 30" sand filter, Pentair Mastertemp 400k BTU heater, 1hp Whisperflo for waterfalls, and a blower for spa floor
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Hey, good to see the photos showing up. I'll be checking back to see how it's goin. Looking good so far!
    Essential Links:
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    Well the guys came to the house for a couple of hours yesterday. They got the second skimmer in, and the line between them connected.
    And I guess these are the inlets
    I'm guessing they haven't installed the spa's rebar yet b/c of the complexity of plumbing that will need to go inside it. just a guess.
    I take pics after each day that the workers are at my house. I usually use my real camera, but I've found it's easier to share pics w/ my iphone, so I'll have daily updates :P
    Every so often I'll update the photobucket album with pics from real camera as well.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Looks like one of each. The one with the "mouth" is a skimmer. It looks like the other may be a return to the pool.
    Interesting though, I've never seen pics where they ran the skimmer line inside the pool/gunite. Usually, these are trenched outside the pool. Perhaps they did that because of limited space. You would have to ask.
    As for spa construction, it is complicated, but it normally comes along with everything else. One thing I've learned is that PB's have some different ways of doing things. Coming along though, and thanks for updating. I'm sick of seeing mine like it is, so it's good to see someone else's moving. It's weather for us though, the tile just came last week, and as you know we are back to nastiness again.
    VERY tired of Winter!!!
    Essential Links:
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    Quote Originally Posted by Brushpup View Post
    Yeah Xavier told me the Flexline was due to limited space...We already have the water feed for the house running between the pool and house, sewer runs other way around pool....lots of pipe in a limited space.
    They were at the house today some, I believe they may return as one left his truck....They worked on the spa (digging some, and putting up the MDF) Pics of todays progress will come tonight or tomorrow.
    EDIT: yup, they came back. woohoo. I love it when they are there! = progress.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I see...figured there had to be some reason. We'll move on ours late this week or early next acoording to PB. Waiting on in to warm up.
    Essential Links:
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    Don't look @ the weather for Thurs. I did...and I'm sad.
    Readyforapool's Avatar
    Sep 2013
    DFW metroplex
    738
    All I can tell you is don't be too sad, as someone who is a bit further along - watering gunite and brushing plaster when it's freezing cold is not fun... Here's hoping things warm up soon for y'all! I'm still trying to thaw out, maybe June before it happens!
    Finally Done! - 21x34 IG, SWCG, depth - 3.6 - 4.6 - 6.6, Pentair IntelliFlow 3050 vs+svrs, 60 sq ft Pentair DE Filter, 400k BTU Heater, Polaris 280 w/.75 hp booster pump, Pentair EasyTouch wireless, 38 sq ft raised spa, wet edge Barbados quartz finish - ODK w/36 in Napoleon grill
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    Quote Originally Posted by Readyforapool View Post
    LOL. That I believe. I was rather uncomfortable just taking these pics yesterday. I believe it topped out around 36deg. I hate winter.
    Anywho, as promised. this is 2/3/14's progress...
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Well, at least it's a little progress. Doesn't look like the weather will favor us this week though.
    Essential Links:
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    Yeah, They are working on the plumbing in the spa today since it's finally moderately warm. I'm betting they work as much this week as possible to get to that #2 draw.
    pragmatic's Avatar
    Jul 2011
    Friendswood, TX
    521
    Yes sir, that's coming along nicely! I see that dreaded Caliche again. I complain about our Texas Gumbo (Mud), but it has it's benefits. Keep updating
    Dave My Pool Build, ODK Build
    22X42 Gunite Freeform 23K Gal, 10X12 Spa
    Diamond-Brite midnight blue, 1800sq. ft Kool Deck
    Pentair Easy-Touch 8, 2-2hp Pentair, 500lb Sand Filter, 400K btu Pentair heater
    bhargraves's Avatar
    Nov 2013
    North Texas
    183
    The caliche isn't such a bad thing, except in cases where the PB charges you for digging in it! It should provide a nice, stable base for the pool to sit on, and not cause structural issues due to expansion/contraction. We lucked out in that they ran into caliche, but were able to get through it with the excavator, and the dump site was willing to take it (back-fill for a house that was removed). Dodged an expensive bullet!
    Build Complete! : 111ft pool + 8.5x5.5ft spa (12" raised), ~22k gallons, Shotcrete, Stonescapes MiniPebble (Aqua Blue), 3 scuppers, 3 bubblers, Large Tanning Ledge, Long Bench, Pentair: Intelliflow 3050 VS, 1.5HP WhisperFlow (scuppers), Quad 100 DE filter, MasterTemp 400k, IC60 SWG, Intellichem+Acid Tank, 2HP Silencer Blower, travertine decking (~680ft2), dry stack flagstone raised wall / spa spillway
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    Yeah. I compromised on the depth of my pool. I wanted 8ft+. But. The owner/operator of the backhoe already broke the backhoe once in my backyard. They weren't willing to go any more without a jackhammer. That was going to run another 1000.00+ For about 30 mins of hammer time. (Hehehe. Hammer time).
    I came home early today. Here's a pic of today's work. A little plumbing in the spa. And some rebar work.
    Question for u guys...does that seat angle look pretty extreme? I believe u don't want it perfectly flat. To keep dirt and such from settling on the seat. But this looks a bit extreme to my untrained eye. I trust em. But I don't want to assume they are always right.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    So that is the spa seat? If so, it does look a little steep to me.
    I'm not sure why you would want or need it to be....
    Did you plan on e slope in the design? There are lots of Spas shown here, and I don't recall seeing sloped seats like that. There is another build running right now where they "scalloped" some seats out, but I don't understand this one. Do update us on it.
    Essential Links:
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    I'll have a chat w/ him. Looks off to me as well. The pools I've seen of his don't have sloped seats like this...and I certainly don't want it.
    I don't know what "e slope" is...
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    That should have been a slope, not e slope. Sorry, typo.
    I hear ya. I wouldn't either. Maybe there is more to the story. I'm sure you can resolve this easily.
    Essential Links:
  20. Back To Top    #20
    Feb 2014
    Upstate, NY
    390
    Are these the 2 returns?? Post# 16 (Picture of PVC flex pipe against rebar). Shouldn't they be in a "looped" system???
    20X36 IG vinyl (18,000 gal), 3 sheer descents, Max-Flo 1.5hp VS 2300, Aquarite T15 SWG, C3030 filter, 250,000 BTU heater, Sharkvac XL (Hayward equip)
