Thread: automatic chlorinator setting
    May 2008
    Clover, SC
    11
    I was wondering what I shuold set the chlorinator at to keep from getting to much CYA or not have enough . My pool is 16' x 32', 22,000 gal with a hayward filter system. Last year I had to close my pool in August, because of algae. The CYA level was to high and with the drought we had here in S.C., I wasn't able to drain it and refill to get the level down. So the algae made it's self at home until now. I don't want it to get out of hand now, especially since it looks like we might be in drought again. It has taken me a month to get it swimable. Thanks, R.D.
    Roger Dean Helms
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: automatic chlorinator setting
    The problem is that if you set it high enough to maintain the chlorine, the CYA will get too high. The only options are regular water changes or quit using the chlorinator.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Roger, it always comes back to testing the chem levels!!
    This post discusses some of the things you're asking about read me. I don't want to sound like a broken record, but re-reading the Pool School info is always! helpful
    With potential water restrictions, you want to make sure that your cya level doesn't get too high (you should also insure that any teenage offspring don't get too high ) - as such, when the tablets have gotten you to a cya level that you are comfortable with, simply switch to unscented bleach as your chlorine source This info is all over TFP, but can always bear repeating
    Luv& Luk
    -Ted
