Results 1 to 9 of 9
Thread: pip dope or tape?
    Jul 2011
    phoenix
    133
    pip dope or tape?
    I replumbed my pad last year and appears I have a leak, well two now. One at the elbow after the pump going to the filter (probably not enough glue). And the second one appears to be coming from the threaded insert that goes in the pump. I used dope on it last year and wondering what could be causing it to leak (dribble but still a leak).
    13k IG pebble pool w/waterfall, 1hp whisperflow pump, pentair ccp320 cartridge filter
    Circupool SI45+ swg
    TF100 +speed stir Taylor 1766 salt test
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    pip dope or tape?
    I'm a thread sealant "paste" type of guy all the way for my threaded fittings.
    If it's got a leak, take it apart, clean the old sealant off the threads and re-apply the thread sealant.
    Jeff
    22,553
    Re: pip dope or tape?
    I'm a paste guy too. Just be sure to get the type for plastic piping.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I guess someone has to vote for tape, but I have a good bit of experience with it on high pressure and fuel lines, etc. I think paste is easier and tape tends to work better if it is done right.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Quote Originally Posted by Isaac-1 View Post
    That's the key with tape, has to be done right. I've used tape, I just use it on small dia. fittings. On the big stuff I go with the paste. It's never failed me.
    Jeff
    Jul 2011
    phoenix
    133
    Thanks for the feedback/advice. I will be redoing it again coming weekend and will probably try a different thread sealant. I could not find the can of the one I used but I am positive it was http://www.homedepot.com/p/Oatey-Gre...ct_description that I used. Said it was good for plastics but maybe will try looking for one that specifically says pvc
    Circupool SI45+ swg
    Quote Originally Posted by pwrstrk View Post
    What is the "correct" way to use the tape? I've successfully used the tape quite often with indoor plumbing on 1/2" lines and such, but I am not having much success on my 1 1/2" fittings on the swimming pool.
    12Kgal, AG, Sand, Hayward Swim Pro SW256T PAKS
    30,431
    That has been my experience as well.
    I think you know we have had this discussion several times on the forum and what we learn is that everyone does it a bit differently.
    The ultimate answer is probably to do what you are comfortable with. I am comfortable taping 1" or less and doping 1.25" or greater but it's only because I have done that before and it "feels" right to me......not because it is the definitive answer.
    There are likely many on this forum that can easily tape a 3" joint or dope a 1/2" joint.
    Of course, if you are helping someone inexperienced, you should slap them upside the head if they try to do it any way but your way......they will marvel at your great skills!
