Thread: Winter storm warning and loss of electricity.
    Aug 2010
    Charleston, South Carolina
    77
    There's a chance of an ice storm down here in South Carolina. My Pentair pump automatically comes on when the temp drops to freezing but what if I lose power? Anyone have any suggestions to keep the pump or pipes from freezing?
    half Inground/half above ground, shotcrete pool, 19,000 gallons - KrystalKrete Krystal Blue quartz finish
    Pentair intelliflo variable speed pump - Pentair Easy Touch automation - Pentair T100 sand filter - Savi Melody LED lights - Mortex KoolDeck - Charleston, South Carolina
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Winter storm warning and loss of electricity.
    We were hit by it today here in Louisiana, nothing severe, but some roads closed due to ice, etc. and did loose power for 4 or 5 hours with the temperatures were in the 20's. I am just thankful to have a standby generator, I remember when I had it hooked up the electrician thought I was crazy to want the pool pump connected to it. In the event of a power loss without a generator about the best you can do is to drain the filter and the pump (there will be drain plugs on the pump, at least 2 maybe 4)
    Ike
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    What is your water temp and expected air temps?
    I'd figure out where all the drains are on your filter and pump and anything else that has water in it now while you can see. Those things above ground are the biggest concern for freezing.
    Whether you need to be concerned about the skimmer depends on how it's installed and what the temps are.
    38,284
    Throw a tarp over the pool equipment with a lamp underneath to add warmth ...
    But if the electricity went out, safest is to just drain the filter and pump.
    Aug 2010
    77
    Water temp is currently 44. Air temps are expected to be around upper 20s. Heading out now to locate the drain plugs in case the power does go down.
    38,284
    How long would it be below freezing? Likely it is not cold enough for long enough for anything to happen even if you did not run the pump at all. Takes many hours for a 2" pipe to freeze solid ... especially if you had a tarp over it to block the wind.
