Results 1 to 10 of 10
Thread: Jandy Aquapure 1400...How fast will it boost the chlorine levels?
    Jul 2011
    Las Vegas, Nevada
    139
    We finally hit 51 degrees in the pool today so I wanted to boost the chlorine before it cools back down. If I run it at 100% will I get enough chlorine in a few hours to make a difference? I am just wondering if I should leave it on or turn it off until temps are consistent.
    Jay...12,500 gallon freeform pool and attached spa w/ Bullfrog Oscillator & ClusterSpray Jetpaks
    Jandy 2hp VS pump(main), Jandy 2hp Stealth pump(Jetpaks), Jandy 1hp Stealth pump(water features) Jandy CL-580 filter, Jandy Watercolors LED lighting, Jandy Aqualink RS8(revision MM) w/Aquapalm, Autelis Controller, Onetouch controller, Jandy Aquapure 1400 SWG, Jandy LXi 400k heater, Paramount PV3 6 zone infloor cleaning system
    38,457
    Re: Jandy Aquapure 1400...How fast will it boost the chlorine levels?
    Not worth the effort. Just pour a jug of bleach in if you want a temp boost of FC. (Ideally use PoolMath to tell you how much to add for a desired effect)
    Jul 2011
    Las Vegas, Nevada
    139
    Actually it would be more effort to go buy more than to use the system. I am just not sure if it is ok for it to kick on and off as it goes above and below 50 degrees. I was told that 50 is when it stops working. I just didn't know if I could leave it on when the temp is too low or if it would mess something up. If I could leave it on and have it operate during the day when temps rise above 50 that would be great, but is a few hours at 100% going to be enough? I would think so.
    38,457
    Well, at best it can produce 1.25 lbs of chlorine per day, that is 12ppm in your pool.
    So, running on 100% will add 0.5ppm FC per hour at best performance (not likely at these low temps)
    Adding one 121oz bottle of 8.25% chlorine will add 6.4ppm FC in a few minutes.
    Jul 2011
    Las Vegas, Nevada
    139
    Thanks, Jason. That is the best info I have found yet. It's cold enough that algae hasn't grown yet, but it will soon as it starts warming up more. If I can get a little bit in each day I should be able to stay ahead of it. I tossed a couple pucks in the floaters just in case. I should know all about this SWG set up by now, but it's been nothing but problematic getting it operating correctly.
    Oct 2007
    Parkland, FL
    752
    Quote Originally Posted by Owner/Builder View Post
    if you want to boost, you don't turn the chlorinator up, that will just burn up your cell quickly. Would you rather spend 5 bucks to boost your chlorine or 50 when you burn a 1/4 of your cell up?
    8000 gal diamond brite pool with 650 gal spillover spa, Pentair 3hp VS pump. Jandy Cartridge filter and Jandy Heat Pump. Jandy PDA automation system with 2 Pentair Laminars. SmartPool NC74S Robotic Pool Cleaner.
    38,457
    Running 2 hours on 100% is the same wear as running 8 hours at 25% ... far from burning up a 1/4 of the cells life.
    Oct 2007
    Parkland, FL
    752
    Still doesn't make sense when 5 bucks in chlorine do the job better.
    Jul 2011
    Las Vegas, Nevada
    139
    Why spend $5 for chlorine when I have a chlorine generator? The system actually has a boost function which runs it at 100% for 24hrs. It is a normally used function so I don't see how running it at 100% for a few hours each day is going to burn the cell up. I just wanted to make sure that it turning on and off because of low temps wouldn't hurt anything. In just a couple weeks the water temps will be constantly above 50 even at night so I will have no need to keep chlorine on hand like i normally do during the winter.
    38,457
    What you are proposing should be fine ... if it generates enough FC (which is a big if).
    SWGs are slow to add FC, thus our recommendation to always use bleach if you need a quick boost ... even in the summer.
