Results 1 to 16 of 16
Thread: My Outdoor Stereo Build...
    NoFear95's Avatar
    Mar 2013
    Phoenix, Az.
    138
    So after wrapping up the fireplace the wife wanted to add some sounds to our backyard get away. We wanted to be able to stream off Directv and pandora. So my build list was as follows:
    -4x 150w Rock speakers from Amazon ~$230 http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
    -500 feet of 14 gauge speaker wire ~$46 from Ebay (used only 400 ft...was actually cheaper to buy 500 ft vs 2x 200 ft rolls)
    -Amp ended up getting for $126 shipped off Ebay but here is the unit http://www.outdoorspeakerdepot.com/a...annel-amp.html
    -2x volume controls so I could vary the level from the pool and the patio. Ended up getting 2x shipped off Ebay for $47 total. http://www.outdoorspeakerdepot.com/ovst10ouvoco.html
    Variety of plastic electrical pipe & wall hook-ups to get the wiring from outside in... $30
    All in about $479...
    Will post up some after pictures. But took a good 6 hours to get the install done and buried the wiring etc.. Sounds is super clear, the amp has plenty of punch to fill the backyard and if I turn it up enough it for sure will drive my nieghbors crazy. So it was a good choice.
    I know the speakers can take more an a larger amp is probably on my bucketlist if I come across a good one at a good price. But for $126, I couldn't pass it up. I am thinking of adding a Bluetooth streaming device an maybe a Ipod & Android hook up for music.
    Any advice would be appreciated...
    IG, 18K gallons, 100' Perimeter, 565 SF surface area, 980sf interior area, Max Length -36', Max Width - 16', Pentair 520 Clean and Clear Cartridge Filter, Stenner Chemical Injection System (Chlorine, Acid Coming Soon) , Pebble Tech - Blue Granite, Pentair variable speed filter pump, Zodiac MX8 Cleaner, Multi-Colored LED Lighting, Travertine coping & Decking, Boulder Water Fall....
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: My Outdoor Stereo Build...
    Thanks for posting the details. Always nice to know what other people have had luck with.
    I'm mulling the idea myself. Some of my wants are:
    Two selectable speaker "zones". Outside by the pool and inside the pool house.
    Bluetooth input to the amp. Here is my plan if I can't find an amp with it integrated
    Satellite Receiver Input.
    Waterproof remote volume control.
    I already have two runs of speaker wire into the house that I put in conduit when I did my water line.
    Jan 2011
    Richmond, Texas
    595
    Looks good. I tried streaming music from my IPhone to an Apple airport express, but I had to many issues with drops. I couldn't walk around the backyard without it constantly stopping. I then found I could use Itunes on my pc to connect to the airport express and then remote control itunes via my phone. I still haven't figured out a way to stream Pandora yet. They even have apps on Andriod to control ITunes which I now have since I got a galaxy note.
    Approx 11K Gal. 10'X30' Semi free-form IG - 6 ' raised spa w/6 jets - 10' circle sun shelf with 1 bubbler - Waterfall - 3 / 1.5 HP pumps - Polaris 280 Cleaner - 3 Pentair Color LED Intellibrite Lights - Pentair 400K Master Temp - 2 Valve Actuators - 5 Fiberstar Mini Laminars - 1 Fiberstars 2004 Illuminator - 2 Skimmers - 6 Returns - Caribbean Blue Pebble Tech - 600+ sq ft kool decK - Auto Fill - 2 Boston Acoustics VOYA RK5 Outdoor Rock Speakers - 2 TIC Corporation TFS5CN 6.5-Inch 150-Watt Terra-Forms Rock Speakers - Apple Airport Express - 1 Awesome View.
    NoFear95's Avatar
    Mar 2013
    Phoenix, Az.
    138
    I have my "Smart TV" hooked into the amp. So I can stream from Pandora via the the TV. I've only had it drop a few times and it is pretty nice since it runs pretty commercial free through the TV ap.
    Jul 2013
    Carrollton, TX
    40
    I have a pretty similar setup to NoFear95 and included this bluetooth receiver. http://www.amazon.com/HomeSpot-NFC-e...3&keywords=nfc Works great and I get 30-40 ft range through a wall with windows. All our music is on Google Music and it streams flawlessly.
    Quote Originally Posted by JohnT View Post
    I use the following receiver and it works great. A zone is outside and B zone is inside. http://www.amazon.com/Sherwood-RX-41...words=sherwood
    14,000 gal IG + spa, DE Filter, 400k BTU heater, Polaris 280, Aqualink RS6, TF-100 Test Kit
    NoFear95's Avatar
    Mar 2013
    Phoenix, Az.
    138
    That is the exact one I was looking to get! Time to place an order!
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    825
    Good luck with your install. Nothing beats quality outdoor speakers and a good amp. I put some Polk Audio 65SDis outside and they are unreal. I'll really enjoy them around the pool this year. One thing though is the range on some BT receivers can be sketchy. I tried a few and ended up loving the Miccus Home RTX. As a receiver, I easily get 80' or so from the receiver for BT range. Unreal and way better than some of the other ones I tried.
    http://www.amazon.com/Miccus-Home-RT...iccus+home+rtx
    It says receiving range is only 40' but I found that to be way underrated. It's usually the opposite. Your mileage may vary, but this is what I found. Good luck!
    24'x40' 25k gal Imperial Mountain Pond IGP, full 28 mil VynAll Ocean Breakers liner. All Hayward system: 140k BTU HeatPro heat pump, 3/4HP single speed TriStar 2" Pump, DE6020 filter, AquaPlus Automation/Salt Chlorination, remote controls, ColorLogic 4.0 lighting. Polaris 280 w/PB4-60 BP. TF100 & K1766 test kits. Rinox Palazzo pavers and Spherik coping. Pool installed 9/2013, project completed 6/16/14.
    NoFear95's Avatar
    Mar 2013
    Phoenix, Az.
    138
    40 Feet would be more than sufficient for my receiver to patio distance.
    pragmatic's Avatar
    Jul 2011
    Friendswood, TX
    521
    Quote Originally Posted by NoFear95 View Post
    Thanks for posting the details! I already have under-patio sound but it's controlled from inside (pain). The outdoor amp is an excellent option; I picked up the same one with the volume control. They are stout and great price as well. I haven't decided on details (placement and speakers), but I have power and control so I'll get there soon enough. FWIW, I would suggest purchasing the Pandora plan ($30/year), but no commercials and a higher quality feed (bit/rate based I believe). My neighbors think I have the largest music collection ever
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    How is the install coming along? I'm in the pre-planning stages at the moment. Your build has my interest.
    IG gunite/plaster pool/spa Started 1/17/14, Plastered 5/16/14
    Size: 12'-21'x39' free form, depth ranging from 4' to 7, attached 6 person spa with spillover.
    Equipment: Whisperflo 2hp pump, Pentair 30" sand filter, Pentair Mastertemp 400k BTU heater, 1hp Whisperflo for waterfalls, and a blower for spa floor
    NoFear95's Avatar
    Mar 2013
    Phoenix, Az.
    138
    Good finished it up about 2 weeks ago. I will post up some "after" pictures tonight or tomorrow.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Very cool, gives me some food for thought. I need to do something new this year if possible.
    Essential Links:
    NoFear95's Avatar
    Mar 2013
    Phoenix, Az.
    138
    They blend in quite well. Ill snap a picture of the outdoor volume controls soon!
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    They really do blend in nicely. Thanks for sharing the pics.
    NoFear95's Avatar
    Mar 2013
    Phoenix, Az.
    138
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    oh those look nice as well.
