Thread: Is a pool aerator needed if rain sheer is going in(pool remodel)?
    Oct 2013
    Phoenix area
    91
    Probably a dumb question but wanted to get some input. I am in a pool remodel and adding a rain sheer which will be much more affective of cooling or agitating any water.c
    The aerator is a fan type mounted along the deck. Any possible reason to keep it??
    13,000 gallon IG
    PCC IG cleaning system
    Pentair equip.
    Attached spa
    Dire need for surface refinish!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Is a pool aerator needed if rain sheer is going in(pool remodel)?
    Is there a way to keep it just so you can access it later if wanted? You may not need it, but then again...
    Just a thought, since the sheer may be all you ever need from here on out.
    Essential Links:
    Oct 2013
    Phoenix area
    91
    Sounds like I could live without it, here in Phoenix I think they are common but at 120 deg nothing really helps! We haven't used it much other than the kids want to play with it.
    I thought about leaving it too (why not) but the spout is right at my water tile and (raised beam)stone joint line, moving it up might be more work than necessary.
    Thanks for the reply...
    13,000 gallon IG
    Pentair equip.
    Attached spa
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    You're welcome, for what little it was. Sounds like you could do without it.
    Essential Links:
