mvrisch said:First question - how "not visible" should the dot be? No dot at all? Obscured but can see black? Any help here is helpful.
Here's a visual: http://www.taylortechnologies.com/Chemi ... ntentID=44
mvrisch said:Second question: What does a pink PH mean? High or low? We had a lot of rain, which I assumed would lower the PH.
mvrisch said:CYA (black dot test) shows at about 60. The strip shows a little more maroon than that, which implies a higher CYA. Do not trust strips, trust the "black dot"
No dot at all
PH (phenol red) shows a pinkish color, which I read to be somewhere between 7.2 and 7.6. However, the strip seemed to imply 7.8 or higher with an much more orange color. Again don't trust strips
Salt read 5.0-5.1 on the strip (2750 PPM or so). I added 50lb bag, and now it reads a clear 5.6 (3380). Here's the strangeness - if my pool is the dimensions above, it is about 21000 gallons, which means that 50lbs should up salt by 300, not 600. There is no way (I don't think) that this is a 10,000 gallon pool.
Third question: Why is my salt going up so much with so little? This is not the first time - I initially added 550lbs, and it took my salt to 4300, which was much higher than it should have. Do I just have extra potent salt?
Fourth question: My target salt is 3500. I'm afraid to add more as it will likely put me over. Does the SWG lower the salt lever when it is in operation (it is off now), such that I should add more, or should I just leave the salt at 3400 and be done?
leave at 3400
I will likely go to a pool store to get everything retested, but your tips on the above so I can read my own test results accurately would be helpful.
My free chlorine was insanely high (16) and remains high after the drain. I suspect it is the high CYA that did it, as the SWG was only on 30%. I am going to leave it off a couple days, re-test, and then go to 10%.
