Results 1 to 11 of 11
Thread: pentair easytouch wiresless remote
    Hi,
    I am currently trying to install my easytouch 4 automation system. The load center is mounted and powered up. Now I am attempting to install the wireless transceiver and the directions say not to install directly to load center or on a stucco wall and be at least 5 feet away due to interference. Where the heck to people mount these things??? On a post in the middle of the yard? Im not sure where most people mount these because the load center is mounted to my house and it only comes with 10 feet of wire for connections to the load center. Any help would be great. Thanks
    22,551
    Re: pentair easytouch wiresless remote
    Is your house stucco? If it isn't, just mount it to the wall a couple of feet away from the load center.
    Mine is 10 feet up on the rear stucco wall of the house.
    Works great.
    Easytouch, Intelliflo, Intellichem, Acid tank with pump, Intellichlor and Autelis network interface.
    Judodad's Avatar
    Jan 2014
    Burleson, Texas
    12
    Mine is mounted right next to my panel. No problems in 3 years.
    17k gal., IG, Pebble Sheen,150 GPM Cartridge CCP420 Pentair 420 Sq.ft Filter, 3 HP Pentair Intelliflo VS-3050 Pump, Letro Legend 4 Wheel Cleaner, 2 HP Pentair Booster Pump, Pentair Intellichlor SWG, Easy Touch Control System With Remote, Intellibrite Led Light, Waterfall, Oklahoma Flagstone Coping, Tanning Ledge w Bubblers, 2 Skimmers, 4 Returns, Built In January 2011.
    Ok. Thanks for the info. My walls are stucco, but it seems that everyone mounts there anyway. I will try that. Thanks everyone
    22,551
    The issue they're worried about with stucco is the metal mesh used to support it. It tends to be attenuate the wireless signal. It may work fine, you'll just have to try it.
    I have honestly tried everything I can think of. I wrapped antenna in tin foil. no help. I moved off the stucco wall, no help. I can't get this thing to lock on an address. the Pentair tech support was no help all. Is there anything I can look for like flashing lights on the transceiver board or anything. I feel like everything works, but I am missing something. firmware version? reboot? is there any tricks I am missing?
    Which part number wireless remote do you have?
    Is this the procedure you are using? Page 11
    http://www.pentairpool.com/pdfs/easy...scontrolUG.pdf
    I will look at part number when I get home. Yes, I used that exact procedure and the remote just keeps trying to link up the address. Never locks on and starts working. Its like it doesnt see the transceiver or something, but before I say the board is bad I wanted to know if there was a technique to troubleshoot, ie. flashing lights, voltages or anything else that I might be missing.
    I would contact Pentair for a RMA
    Jerryt, thanks for the help. I did end replacing the transceiver board and it works great. I guess I got a bad one right out of the box. I did notice my new board has like a built in antenna, where the original board had a screw on antenna. Maybe it was wrong one somehow I don know. It was brand new out of the box. Works good now though
