Thread: Youtube links seem to be broken
    mas985's Avatar
    Pleasanton, CA
    11,737
    Look at this old sticky:
    http://www.troublefreepool.com/threa...itation-Videos
    The fonts seem to have changed too.
    Mark
    38,254
    Re: Youtube links seem to be broken
    Yeah, the fonts thing is an ongoing issue ... setting a size apparently means different things to the different software. I would just suggest changing the font size for these things when you run across them.
    Not sure about the Youtube links though.
    Fixed.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Thanks!
    Mark
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I know VB has an option to turn off imbedding/video links.
    Thanks Jason whatever you did.
    Essential Links:
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Hmmmmmm, let's test this....
