Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: First post, could use some help
    Feb 2010
    Visalia, CA
    8
    Long story short, bought house 4 years ago. Came with the pool. Used Lesliepool to test and treat for the first year. Got sick of making the 20mi drive and spending 40$ every week with unsatisfactory results, so I got a pool guy...
    Pool Guy was great for the first year and a half...then it started going south...
    Got rid of pool Guy back in December...
    Drained pool... pressure washed the .5" of DE off of everything... found what pool guy broke... Replaced the backwash valve in bottom of the filter...
    filled pool with well water, tossed two tabs in the skimmer basket.
    Took sample to lesliepool yesterday.
    Free Chlorine = 0
    Total Chlorine = 0
    Calcium Hardness= 320
    Cyanuric Acid = 0
    Total Alkalinity =250
    PH = 8
    Acid demand = 2
    Copper = 0
    Iron = 0
    Total dissolved solids = 0
    Phosphates = 200
    Added .5gal of muriatic acid last night, let pump run for 4hrs per lesliespool's recommendation
    Guessing pool is 30,000 gal, pebble tech surface
    Have had high pH from day one
    I know I need to get a test kit, Just haven't pulled the trigger on one that fits my needs.
    I'll try to add some pics in a second.
    My question... what do I need to do to make it look like a pool not a pond?
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    Re: First post, could use some help
    I'm no expert, just a newb....but based on my reading here the first thing everyone suggests is stop going to Leslie, and get your own test kit. I saw that this is in your plans...but this should be step one.
    Apparently Pool store water testing is worth zilch more often than not.
    Have you read about the "BBB" method? I've noticed it is highly recommended on virtually every pool owners forum. there's another method "SLAM" IIRC which should help you get from green pond to blue oasis. But it should be reiterated that none of this can be done reliably w/o a test kit.
    IG gunite/plaster pool/spa Started 1/17/14, Plastered 5/16/14
    Size: 12'-21'x39' free form, depth ranging from 4' to 7, attached 6 person spa with spillover.
    Equipment: Whisperflo 2hp pump, Pentair 30" sand filter, Pentair Mastertemp 400k BTU heater, 1hp Whisperflo for waterfalls, and a blower for spa floor
    Aug 2010
    Dallas, TX
    4,052
    Hello, and welcome to TFP! We will have your pool looking great before you can swim, for sure!
    First thing, to make sure they don't steer you the wrong way, don't add any CalHypo to your pool (Leslie's calls it Power Powder). Your CH is already in range and if you add any more you'll be over the recommended top end.
    The test kit you need is the TF-100 or the K-2006. Note the K-2005 won't have the FAS-DPD chlorine test you'll need. You can find both at http://tftestkits.net
    You need to SLAM the pool. My recommendation right now is to do this:
    1. Order the test kit so it can get on the way
    2. Read about the SLAM process here: http://www.troublefreepool.com/conte...tain-shockingl
    3. Ask questions, prepare for the SLAM while your test kit is on the way
    38,301
    Quote Originally Posted by mrcarcrazy View Post
    Just a note that we no longer use the BBB term at this forum. We refer to our methods as the TFPC method.
    We found that the meaning of the B's ended up with confusion for new members thinking that they had to buy all the Bs, when in reality many people NEVER use 2 of them.
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    TFPC, a new acronym? You're killing me
    Trouble Free pool Chlorine?
    38,301
    It is the first article in the "Handy Reference" area of Pool School .... Trouble Free Pool Care method
    Feb 2010
    Visalia, CA
    8
    Thanks for the advice Robbie & mrcarcrazy, thanks for hijacking my first thread jblizzle.
    I've lurked for awhile, so yeah I have read up on the bbb or as its now called TFPC.
    While I'm waiting for the test kit what should I be stalking up on?
    Bleach? The pool math calculator gives me 249oz of 6% of bleach needs to be added. so 2 gallons to start, should I expect on using lots of bleach for the next couple of weeks to get it up to snuff?
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Are you sure it's 6% bleach. Most bleach now is 8.25% unless you have some older bleach, and then I would question its strength being old.
    Jeff
    Feb 2010
    Visalia, CA
    8
    Quote Originally Posted by RobbieH View Post
    According to the Chlorine / CYA Chart my shock level would be 10. Currently my lvl is @ 0, The PoolMath Calculator is kicking out 49gal of 6% bleach to be added.
    Do I need such a high shock lvl when my CYA is 0? I'm guessing not...?
    Quote Originally Posted by pwrstrk View Post
    That is just the original setting on the Calculator. I changed it to 8.25%, thanks!
    Now its kicking out 39gal of 8.25% bleach... to reach 10 for the shock lvl
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Welcome to tfp, weak-link
    For a 30000 gallon pool, I am getting 452 ounces of 8.25% bleach to go up 10 ppm FC. I bet you put in an extra digit in the pool volume box.
    Feb 2010
    Visalia, CA
    8
    Quote Originally Posted by linen View Post
    yeah your right, my bad
    I was starting to think you guys we're nuts with this bleach thing...39gal!!!
    Isaac-1's Avatar
    SW Louisiana
    6,711
    First let me say welcome, second let me say "pardon our progress" we are on all new forum software here that just went live today after everything being down for the weekend, so we are all getting used to the new feel of the place.
    My advice, read the pool school articles in the upper right of this page, order a good test kit, I use the TF-100 (see the link in my signature), and remember step one on any journey is knowing where you are starting from.
    Ike
    38,301
    Welcome to TFP!!!
    I would like to add another apology ... you just happen to be the guinea pig as the first active new member to join after we switched software. As such we have found that all your post have been needing to get approved by a moderator (instead of only the first like the old software). So, your posts may have been delayed showing up on the forum and could have been approved out of order. We are starting to get the hang of things.
    As others have stated. With one of the recommended test kits, the information in Pool School, and all of our members available to answer questions ... you will quickly be on your way to a sparkling pool.
    Feb 2010
    Visalia, CA
    8
    No worries... I'm not a new member... But I am posting for the first time.
    Question,
    Will a cheap test kit get me through lowering the pH and starting with the slam/shock.
    I ask because I'd like to get it started ASAP. While I'm waiting on a tft-100 kit
    Isaac-1's Avatar
    SW Louisiana
    6,711
    A cheap $10 test kit will let you adjust pH, and give you some idea of your chlorine level, but not really enough to accurately perform the SLAM process. On a side note what does your water look like now?
    Ike
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Only an FAS-DPD kit will allow you measure FC levels above 5 ppm. The TF 100 kit will let you do that.
    Jeff
    Feb 2010
    Visalia, CA
    8
    Green
    3-4' of visibility
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    When your kit arrives you'll need to test your CYA level for the SLAM process. Then use the chlorine/ cya chart for your slam level.
    http://www.troublefreepool.com/conte...art-slam-shock
    Jeff
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Yep, sounds like you certainly need to slam, The first step will be getting your pH in line since the pH test does not read accurately at elevated chlorine levels. (FC over about 10 ppm).
    Ike
  20. Back To Top    #20
    38,301
    Since you are in CA, PoolSupplyWorld carries the recommended TF-100 and it should save you some on shipping cost and get to you faster than ordering from tftestkits.net in NC.
