Thread: All the older threads gone?
    Feb 2011
    Petaluma, Ca
    665
    So where is the my pool build thread?, and all the older threads?
    DONE, 20 x 40, inground gunite, 30" raised bond beam with 3 12" sheer descents, 8' diving board, pentair 420 cartridge filter, vs-3050 pump, intellechlor ic-40, auto cvr, Tahoe blue pebble tech, 6ea 4' x 12.5' & 2ea 1' x 12.5' helicol solar panels, legend robotic cleaner.
    38,267
    Re: All the older threads gone?
    No threads are gone ... although if you have a hyperlink, the address may have changed:
    http://www.troublefreepool.com/threa...ol-Petaluma-Ca
    Feb 2011
    Petaluma, Ca
    665
    Thanks, I thought that would be strange. I never noticed there was a filter to set the time period, it was set to only display threads in the last month.
    Mar 2007
    San Rafael, CA USA
    12,082
    Note that one may need to select "Show threads from the" under "Thread Display Options" to "Beginning". It seemed the initial default was to only show threads for the last month. This can also be changed globally under "My Profile" - "General Settings" - "Thread Display Options" - "Default Thread Age Cutoff" setting it to "Show all threads".
    Also, one should go into "My Profile" and set up the "General Settings" since many did not carry over from the old forum software.
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    825
    It does look like any previous thread subscriptions are gone now. I would imagine that's due to the changing URLs.
    24'x40' 25k gal Imperial Mountain Pond IGP, full 28 mil VynAll Ocean Breakers liner. All Hayward system: 140k BTU HeatPro heat pump, 3/4HP single speed TriStar 2" Pump, DE6020 filter, AquaPlus Automation/Salt Chlorination, remote controls, ColorLogic 4.0 lighting. Polaris 280 w/PB4-60 BP. TF100 & K1766 test kits. Rinox Palazzo pavers and Spherik coping. Pool installed 9/2013, project completed 6/16/14.
    38,267
    I believe that you are correct that any Bookmarks or Subscriptions you had on the other software are now gone. I have yet to start organizing this for my reference as well.
    The URLs are different, so if you created a link to a specific thread in your browser, I do not think it will work any more either.
